HEI Limiting Mechanical Advance to 10? - Page 7 - Chevelle Tech
 86Likes
post #91 of 99 (permalink) Old Sep 17th, 19, 12:37 AM
Marcus
Re: HEI Limiting Mechanical Advance to 10?
Originally Posted by nashville beth View Post
Yes, all of my distributors have vacuum advance. I think the best and most original-looking setup would be the points or unilite distributor with a md or pertronix box.
I'll find some way to hide the box.
That's very impressive running 11.08 with that small of a cam !
I have my msd box hidden under the batteri tray.
hydro462 likes this.
Chevelle Malibu ss 64
Th 400 Edge 9.5" converter
Malibu ss 64 is offline
post #92 of 99 (permalink) Old Sep 17th, 19, 6:53 AM
Originally Posted by 69-chvl View Post
let us know how you make out with this. What will the compression be?
10.2:1
Engine is more or less an LS6 crate with a ZZ502 cam instead the [email protected] 114 LSA solid
mr 4 speed is offline
post #93 of 99 (permalink) Old Sep 17th, 19, 5:30 PM
Beth
Just found a brand new Pertronix 512 box for $140.
3 step rev limiter, hi-output ignition, tach connection, shift light
Hope the unilite can trigger it; if not I'll use the points distributor.
GuysMonteSS and hydro462 like this.
nashville beth is offline
post #94 of 99 (permalink) Old Sep 17th, 19, 6:16 PM
Guy
Looks like a good deal Beth !!
Keep us posted when you get it going.
Guy
'86 Monte SS,
513 Stroker,
AFR CNC'd 315 heads,
Isky .904 EZX Roll lifters,
9 inch rearend,
TC Member # 4921
GuysMonteSS is online now
post #95 of 99 (permalink) Old Sep 17th, 19, 9:04 PM
Beth
Guy
Thanks, that's a nice Monte Carlo you got there.
I like that cowl induction setup.
post #96 of 99 (permalink) Old Sep 18th, 19, 7:07 AM
Guy
Thanks for the compliment.
With this induction setup the Big Block gets fresh air all the time.
I got it from Ram Air Box;
Models of Ram Air Box
Guy
'86 Monte SS,
513 Stroker,
9 inch rearend,
TC Member # 4921
post #97 of 99 (permalink) Old Sep 19th, 19, 12:32 PM
Beth
Guy
I wonder why they don't copy the ram air from the old Z28 ? I've seen this on 67 Chevelles too :
Name:	Cowl Induction 1966.jpg
post #98 of 99 (permalink) Old Sep 19th, 19, 12:43 PM
Guy
Their part # 14 X 3C looks quite a bit like that one Beth.
Guy
'86 Monte SS,
513 Stroker,
9 inch rearend,
TC Member # 4921
post #99 of 99 (permalink) Old Sep 20th, 19, 10:22 AM Thread Starter
Those cowl set ups look so nice..
I know a guy who has one on his 67 Impala 396 and he says you can hear the carb real well with them since its tied in with the heater and air ducts...
hydro462 is offline
