Which MSD pro billet should I go for? - Chevelle Tech
 8Likes
post #1 of 24 (permalink) Old Aug 12th, 19, 7:39 AM Thread Starter
I have a 402 bbc fairly stock with a mild cam. I currently have a HEI set up and wanna upgrade to MSD pro billet. Should I go for the MSD85551 mechanical advance or the MSD8361 vacuum advance and why?
moncam is offline
post #2 of 24 (permalink) Old Aug 12th, 19, 8:03 AM
Greg
Is there any particular reason you are taking the hei out?
Are you putting an MSD distributor + an ignition box or just a all in one distributor (forgive me for not looking part numbers you gave up lol)?
If you’re driving on the street, get vacuum advance, tune it right, and you’ll be happy. Or, leave the hei, tune it right, and you’ll be happy with a lot more $ left in your wallet!!
Greg C.
1969 Chevelle Malibu
New, waaaay overcammed 496 "The Dud"
[email protected]
Iforgot is offline
post #3 of 24 (permalink) Old Aug 12th, 19, 8:06 AM
Guy
Re: Which MSD pro billet should I go for?
Well,you're asking to open a can of worms here LOL
Some will tell you to stick with the HEI,others will tell you to buy the GM Performance model,and some will give you other advice.
I have in the past used this MSD distributor,# 8365;
https://www.summitracing.com/int/parts/msd-8365
It had a real nice mechanical advance and IIRC it came with a couple of sets of springs and bushings for tuning.
But,the coil died after less than a year,I replaced it with an old Proform one that worked great;
https://www.summitracing.com/int/par...943c/overview/
Then the module died.
I wasn't impressed with the electronics but the distributor itself was fine.
Guy
'86 Monte SS,
513 Stroker,
AFR CNC'd 315 heads,
Isky .904 EZX Roll lifters,
9 inch rearend,
TC Member # 4921
GuysMonteSS is offline
post #4 of 24 (permalink) Old Aug 12th, 19, 8:45 AM
HEI has been one of the best systems for decades. Long before MSD and the others. If you have a good one I'd keep it.
lucifershammer likes this.
mrpaticular is offline
post #5 of 24 (permalink) Old Aug 12th, 19, 12:32 PM
I have the GM Performance rebranded, and much cheaper, version of the Pro Billet HEI. It has everything that the MSD has except rev limiter. I limited the vacuum advance to 14 degrees and have the 18 degree bushing and I'll eventually get around to remote mounting the coil. It's a good unit, really needs no upgrades.
My very amateur opinion of CDI boxes is that unless one is required to control nitrous, boost or other stuff I'm not familiar with then they just make your car heavier and your wallet lighter, not to mention add complexity and make troubleshooting more difficult. An HEI module seems to do every bit as good and keeping a spare in the car just in case is cheap insurance. But if you move the coil out of the cap it's been said that the modules last indefinitely.
bradley67 likes this.
70 Camino...Roller
Tommy the Cat is online now
post #6 of 24 (permalink) Old Aug 12th, 19, 12:51 PM
Just be sure to replace the gear before you run it.
mr 4 speed and scalise71 like this.
Chris Straub
Mfg Performance Parts
cstraub is offline
post #7 of 24 (permalink) Old Aug 12th, 19, 5:56 PM
VACUUM ADVANCE, because it will work right after you set up the vacuum advance degrees stop correctly (easy to do). DO NOT FALL FOR THE ABSOLUTE INSANITY OF LOCKING THE MECHANICAL ADVANCE OUT, EITHER, leave the curves in place. Run the vacuum advance on full manifold vacuum only (this ois the reason to stop down the vacuum advance degrees, to get 22 to 24 IDLE timing degrees (Initial and vacuum advance degrees combined, example: INITIAL, 16, VACUUM, 8 total IDLE degrees 24)
Dave Ray is offline
post #8 of 24 (permalink) Old Aug 12th, 19, 6:01 PM
Do you have a part number for the GM Performance rebranded distributor? Sounds like a bargain...
lucifershammer is offline
post #9 of 24 (permalink) Old Aug 12th, 19, 6:41 PM
I'll look through my receipts. A quick Google search didn't yield anything. Maybe they aren't selling it anymore.
70 Camino...Roller
post #10 of 24 (permalink) Old Aug 12th, 19, 8:50 PM
This is the one I have- https://www.jegs.com/i/Chevrolet-Per...61867/10002/-1
I paid $262 in March 2016...not sure what happened to the price since then!
70 Camino...Roller
post #11 of 24 (permalink) Old Aug 12th, 19, 9:03 PM
It went up! Lol
Thanks for digging it up though.
post #12 of 24 (permalink) Old Aug 12th, 19, 9:36 PM
Out of the 3 MSD distributors I have both ready to run have failed. The third is used just as a trigger only with a 6A box and it's the only one that is still working.
68Chevele is offline
post #13 of 24 (permalink) Old Aug 12th, 19, 10:41 PM
Here is my problem. I had a BRAND NAME ign. system. ( my car is a driver) When it took a ... Be polite......A POOP...... You will say NOW WHAT! ( call a roll back!)
After one or two issues, I went to K. Ross Chevrolet and bought a H.E.I.
P.S. That was 39.000 miles ago. I do know the G.M.--H.E.I. is still in the 468, Because I looked and I saw it today.
Other than a race car, Or trying to beat " John Force " The G.M.--H.E.I. is the cats MEOW !
Your car, Your Cash, Your choice !
Robinls5 is offline
post #14 of 24 (permalink) Old Aug 13th, 19, 12:40 AM
No, they haven't stopped selling it.
No, it hasn't gone up, it's gone down substantially.
https://www.summitracing.com/parts/ado-93440806
BTW, already has a Melonized distributor gear. One lasted 14 years in my 406 Chevelle, still running when I wrecked the car.
post #15 of 24 (permalink) Old Aug 13th, 19, 12:59 AM
C) None of the above.
