driveshaft vibration... - Page 2 - Chevelle Tech
Top Tech Reference Tech Articles
post #16 of 16 (permalink) Old Jul 27th, 11, 7:09 PM
mak
Re: driveshaft vibration...
Had the problem with my 69 chevelle for about 12 months,drove me crazy.Tried everything,rebuilt the tranny,new driveshaft,still no joy.Found it just recently...... turns out the yoke on the diff end is worn allowing the caps on the u-joint to move out an extra 2mm causing vibration.simple test, loosen the bolts,squeeze the caps together and retighten,then take for a drive and see if there is a difference.Good luck
mak is offline
This Thread is more than 3233 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
You may not post new threads
You may not post replies
