Chevelle Tech - View Single Post - HID upgrade using BMW headlamps (long read)
post #10 of (permalink) Old Jan 28th, 13, 1:03 PM
chuckd71
Stu
Re: HID upgrade using BMW headlamps (long read)
So your highs are the hids and lows are halogen? The lows have a much better cutoff but the highs are pretty spread out.
Here is a pic showing my hid highs in a projector, the cutoff is similar to your lows. Could you put projectors in the highs? Either way the lows look good for sure.
[IMG] 2011-07-17-21-45-41_1000000081[/IMG]
Cool write up and I bet most of it would transfer to using projectors in all 4 spots. Several of the places selling expensive kits are just buying the same parts we could and charging a **** ton for labor. It's much cooler actually making something. Some guy on stevesnovasite did basically what you did except he used projectors from an infiniti or acura and more or less stuck them on the back of the headlight buckets. Can't find the thread at the moment though.
L92 / 200-4r -> T56 71
chuckd71 is offline
