Chevelle Tech - View Single Post - cam and rocker arms
post #2 of (permalink) Old Jan 5th, 13, 1:22 PM
Qwiktripz1320
Josh
Re: cam and rocker arms
Stock springs/rockers are usually only good for around .500 or so. I would run some "911" comp springs, replace the rotators with eliminators if it has them, and and run "long slot" rockers(most have an L cast into them). Elgin makes a nice inexpensive set, I believe you can get them from Competition Products. Also, just to be safe, you should check piston/valve clearance. It's probably OK, but better safe than.....well you know.
1970 ElCamino
440ci "Baby" BBC
Big Shot Plate
TH400 w/Brake
12 bolt
Best#'s- 1.35-5.94-120-9.59-141
Getting it done with 10"
2015 Pinks All Out 8-9sec Winner
Qwiktripz1320 is offline
