12 BOLT to a 9" Ford - Chevelle Tech
2018 General Tech Forum from 2018
post #1 of 16 (permalink) Old Oct 28th, 18, 4:37 PM Thread Starter
We are going from a 12 bolt rear end to a 9" Ford rear end. Any advise on a good supplier for a rear end housing that will bolt in ? Will also be going to disk brakes so the housing will need to be set up for that. Thanks for any information.
ms0115 is offline
post #2 of 16 (permalink) Old Oct 28th, 18, 4:58 PM
Josh
Quick performance is great, really good product made in Ames, Iowa and great price. I looked at all the usual suspects and QP couldn't be beat.
Cheveezy is offline
post #3 of 16 (permalink) Old Oct 28th, 18, 5:21 PM
Andreas
Location: Germany, Osnabrück (where VW Karmann come from )
Re: 12 BOLT to a 9" Ford
Hello.
I‘ve bought my 9“ rear end with eaton truetrac from Quick Performance too and i am very happy with it, only drum brakes-but disc brakes are no Problem there. Many options to choose, not expensive.
Only 6000 Miles this Summer, but no leaks or issuses yet.
Easy to install, only sway bar was a little tricky...
Greets Andi
little Video of my Chevelle Resto:
Andi is offline
post #4 of 16 (permalink) Old Oct 28th, 18, 5:43 PM
Allen
Count me as another happy Quick Performance customer, just received my 2nd Chevelle 9" from them.
Blown1932 is offline
post #5 of 16 (permalink) Old Oct 28th, 18, 5:53 PM
Claude
Strange Engineering have nice bolt-on setups… I have one of their "S60" Dana differential on my Buick GN, fits perfect and comes with all the necessary mounting hardware for disc brakes.
LINK: https://www.strangeengineering.net/p...es-1/ford-9in/
Claude.
1971 Chevelle SS
toofastforyou is offline
post #6 of 16 (permalink) Old Oct 28th, 18, 5:54 PM
Quick Performance 9 inch here as well. No issues. Was cheaper to sell the 12 bolt and take that cash and buy a done 9 inch then to build the 12 bolt.
64 Chevelle 496
StevenS is offline
post #7 of 16 (permalink) Old Oct 28th, 18, 6:01 PM
terry
Quick Performance here too. You can get GM ends on it as well, and the GM disc brake set ups will bolt on...
mytmouz is offline
post #8 of 16 (permalink) Old Oct 28th, 18, 6:03 PM
What is the stock reference vehicle for the 11" drum brakes that Quick Performance uses on their rear ends?
lucifershammer is offline
post #9 of 16 (permalink) Old Oct 28th, 18, 8:16 PM
Allen
The one that just arrived is set up to bolt on 98-02 Camaro rear disks. Had them build it 2" shorter, braced, new housing, drain/fill, heavy wall tube, and new housing; it's impressive.
post #10 of 16 (permalink) Old Oct 28th, 18, 8:46 PM
I'll second the nomination for a Strange rear.
I suggest you consider narrowing it a bit, say 2" total. You'll be able to later space wheels out to where you need them. This makes it easier later to get wide tires. Also consider 1/2"-20 studs.
Make sure it has the large bearing axle flanges and large fill and drain plugs in the rear face.
After you get it, setup your brakes and lines BEFORE installing the rear into the car. I've seen weld on hose end tabs, much nicer than a hose clamp around the tube.
Not sure your wheel size but Wilwood makes a 4 piston kit that fits a stock 15" wheel with the parking brake in the hat. It works well.
LS1tech.com supermoderator.
How may I help you?
1999 Trans Am-500hp
paul bell is offline
post #11 of 16 (permalink) Old Oct 28th, 18, 9:01 PM Thread Starter
We have been running the 12 bolt in a 3,400 lb BBC N/A 67 Chevelle. Running low 5.80's with a 1.26 60' for years and have not had any ring gear problems. But a couple of months ago we twisted a MW hi-torque axle between the bearing and the flange and the tire came off the car. So it is time to go 9" with big bearing ends. We will be running 15" wheels and would like to run the biggest disk brakes that will fit. Thanks for the input.
ms0115 is offline
post #12 of 16 (permalink) Old Oct 28th, 18, 10:15 PM
On my 9" with big bearings, this is the exact kit I used: https://www.wilwood.com/Search/PartNoSearch?q=140-7139
It clears my 8" rally wheels.
How may I help you?
1999 Trans Am-500hp
post #13 of 16 (permalink) Old Oct 28th, 18, 11:44 PM
as mentioned, QP offers good parts at non-boutique prices. Check carefully before buying unless your wallet is just toooo heavy to carry around.
Being able to get it in any width your want is cool. 2" narrow allows to run a good looking wheel with more dish. More than that be careful.
Tom Mobley is online now
post #14 of 16 (permalink) Old Oct 30th, 18, 11:35 AM Thread Starter
Thanks for the help and info.
ms0115 is offline
post #15 of 16 (permalink) Old Oct 30th, 18, 12:15 PM
Greg.
Happy with my S60 from Strange
added in stuff to ensure it would be strong internally (Eaton Tru Trac/Worm Gears) and last long
eg. 11" Drum Brakes / Ford ends / larger studs / Chrome Molley Pinion / LPW Cover
they have lots of options for Brakes etc.
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is offline
This Thread is more than 455 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
You may not post new threads
You may not post replies
