Chevelle Tech - View Single Post - 69 chevelle moved battery to trunk
post #2 of (permalink) Old Jul 22nd, 03, 11:18 AM
John_Muha
Post
I assume you are running a large wire up to the alternator from the starter. You need to for the alternator to charge the battery. If you do that the wire running across the core support will by tied in because the other end of it ties to the horn relay and the horn relay is tied to the alternator.
John_Muha is offline
