Window stain. - Chevelle Tech
post #1 of 4 (permalink) Old May 7th, 19, 4:58 PM Thread Starter
Ken
Window stain.
I'm detailing my SS and I have a stain on the corner of the rear window.It looks like glue or almost an etching.You can barely feel it with your finger.I have used Invisible Glass,Swipe,Spray Nine,paint compound,Dremel with buffing wheel and compound,Razor blade and Lacquer thinner.The lacquer thinner worked on the outside edges but there is still 4 square inchs left.You need to look at it at angle but still very noticeable.When the stain is wet you can hardly see it,but when it dries there it is.
I thought I knew a lot about detailing but this thing has me pulling my hair out and I don't have much to spare.
Any ideas?
396375 is offline
post #2 of 4 (permalink) Old May 9th, 19, 11:58 AM
Levon
Re: Window stain.
Ken, try 0000 steel wool lubricated with window cleaner.
Levon Hovagimian
Team Chevelle #279
1966 427 Corvette SOLD
Priddis Greens, Ab. Canada
LevonH is offline
post #3 of 4 (permalink) Old May 9th, 19, 12:03 PM
Re: Window stain.
^^^^ This... makes all you chrome look like new as well.
"SSuper Dave" Palmer
A.C.E.S. #1483 TC #32 Gold
SSuper Dave is offline
post #4 of 4 (permalink) Old May 9th, 19, 10:46 PM
blm
Re: Window stain.
I assume this is on the outside. If it is just a stain then it should come out. If it is etched into the glass then I don't believe you will be able to remove it. I had etching in my original rear window that looked like someone dripped 3 drops of some kind of acid on the glass. It was permanent and I ended up replacing the window.
blm is offline
Setting glass - Butyl or Urethane? ... AAARG!!! Dave-1970 Body Shop 138 Jan 2nd, 20 3:04 PM
Power window boost 68malibeast Electrical & Wiring 11 Aug 30th, 18 3:16 PM
Installing window regulator in 66 - done! bobinbc_66 Body Shop 1 Apr 11th, 16 8:52 AM
72 Chevelle quarter window removal???? NZChevMuscle Chevelle Tech 5 Nov 17th, 15 12:24 AM
misaligned top? misaligned window? or both? Va72Chevelle Convertibles 27 Jan 21st, 13 12:19 PM
