How to clean off stuck grease - Chevelle Tech
 3Likes
  • 1 Post By Dean
  • 1 Post By 77 cruiser
  • 1 Post By 69SS454
post #1 of 8 (permalink) Old Apr 18th, 19, 10:31 AM Thread Starter
My Chevelle is a pretty solid car, there is no rust on the floor pans or frame. I'm trying to clean up the underside a bit, it has 50+ years of greasy stuff that is pretty thick. Last night I took some laquer thinner and it worked well with some elbow grease but I don't really want to disturb the paint beneath. I'm looking for suggestions on what to cut through the grime with. By the way, my floor pans are painted black, I thought I had seen on this site that they would be a primer red color. Looking at the underside it certainly looks like an untouched original.
Dansk is offline
post #2 of 8 (permalink) Old Apr 18th, 19, 11:02 AM
Hank
Re: How to clean off stuck grease
I used gas in areas on my undercarriage to get the heavy stuff off. It's good at cutting thru undercoat. My floor pans had a red primer look to them. After I sprayed the undercarriage black you can still see the red primer through the holes in the trunk braces.
HKalin is offline
post #3 of 8 (permalink) Old Apr 18th, 19, 11:17 AM
What kind of gas?
I used a propane torch and a putty knife but mine was a combination of old grease and undercoating.
post #4 of 8 (permalink) Old Apr 18th, 19, 11:31 AM
Hank
What kind of gas?
Regular Grade. He's trying not to damage the bottom using a putty knife. It's OK to hit it with a putty knife too as long as you don't try to take it down to the panel itself. On mine I knew I was going to paint it black and it wasn't too bad to start with so areas I felt I needed to use gas I did. After that I scuffed the surface with a wheel that looks like red scotchbrite pad then wiped it down with a PPG degreaser and the rattle canned the whole bottom.
ID:	591810   Click image for larger version
HKalin is offline
post #5 of 8 (permalink) Old Apr 18th, 19, 11:38 AM
I meant Natural, Propane, Laughing, Refrigerant?
Sorry
BTW, yours looks great!
HKalin likes this.
post #6 of 8 (permalink) Old Apr 18th, 19, 1:43 PM
Sorry
That looks like a lot of work so their probably was some fart gas in the mix.
Turned out nice!
HKalin likes this.
77 Monte
11.93 @ 112.7 & tuning
77 cruiser is online now
post #7 of 8 (permalink) Old Apr 18th, 19, 2:33 PM
I use kerosene for though jobs like that. I also use it in my parts washer. I'm sure gasoline would work too, but I can't stand the smell of it.
HKalin likes this.
69SS454 is offline
post #8 of 8 (permalink) Old Apr 18th, 19, 2:52 PM
bob
I used a needle scaler on two Chevelle floor pans then paint thinner. The scaler removes undercoat, thinner removes anything that is left. They look like new.
https://www.harborfreight.com/air-ne...aler-1108.html
bobm67 is offline
This Thread is more than 450 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
tranny stuck in 1st gear forever young Transmission & Driveline 45 Aug 12th, 14 8:58 PM
Fuel pump rod stuck rlasav Engine 5 Jul 3rd, 14 11:20 AM
Grease guns that actually work crankitup Tools & Shops 15 May 22nd, 13 3:23 PM
Window track grease Redmanf1 Restoration Corner 4 Nov 30th, 12 8:53 AM
lower ball joint grease boot 70topless goldrush Brakes, Suspension & Steering 4 Nov 28th, 12 7:24 AM
