Chevelle Tech - View Single Post - air cond. wiring trouble
post #6 of (permalink) Old Aug 8th, 00, 12:26 AM
pmullaly
Phil
Sounds like the a/c relay on the fender is stuck closed.Or the master switch behind the panel is stuck on.(not the fan switch) Verify the switch hooking up a test light to the output side make sure you loose power when deselecting a/c. Or Ohm across the switch with leads removed. If that works normally go to the a/c relay on the fender uplug it and remove it from the fender unbend the tabs holding the dome on.Once its opened youll be able to see if the contact points are welded together. If thats not it then you can reassemble it with no worrys
Philip Mullaly
72 TPI El Camino
If the opposite of Pro is Con,wouldn't the opposite of Progress be Congress
pmullaly is offline
