3" exhaust to header collector question - Chevelle Tech
post #1 of 6 (permalink) Old Apr 4th, 14, 10:55 PM Thread Starter
Gossamer (Mike)
Ok, this seems straight forward but I'm running into roadblocks.
I'm installing 3" exhaust with Dynamax Ultra Flow rounds.......problem is the connection to the header collector. The header collectors are 3" and everybody has 2.5 header to pipe collectors but nobody has 3".
I'm installing this tuesday and went to 4 different places trying to get 3"....even by ordering. They all say they can't order it.
Am I out of the loop here? 3" header collector to 3" inch exhaust pipe means a 3" x 3" collector....right?
My version of the never made '72 SS454 Chevelle Wagon.
454 ATK Engine/550 HP/575 TQ/4.10
gear/T-350 trans./3400 ATI conv/B&M Comp. Shifter/ 1/4 ET-12.39 @108mph - 1.69 60ft.
"Bet I can get to the Grocery Store and back Home first!"
Gossamer454 is offline
post #2 of 6 (permalink) Old Apr 4th, 14, 11:22 PM
Mark
Re: 3" exhaust to header collector question
Do you mean the extensions?
http://www.jegs.com/i/Dynomax/289/88...FYtDMgodNBwA9w
ZZ502 Short block
Holley Avenger MPFI
612HP/594TQ
MarkP is offline
post #3 of 6 (permalink) Old Apr 4th, 14, 11:25 PM Thread Starter
Gossamer (Mike)
No reducers, but in this instance they aren't being reduced any....just simple header collector reducers.
Went ahead and ordered from Summit.....it's pretty bad when you go into auto parts stores that advertise high performance parts that they don't know crap.
post #4 of 6 (permalink) Old Apr 5th, 14, 1:59 AM
Kory
Summit has 10 different ones to choose from 3" collector to 3" pipe "reducers"
http://www.summitracing.com/search/d...meter/3-000-in
67 Chevelle owned since high school
elsolo is offline
post #5 of 6 (permalink) Old Apr 5th, 14, 11:06 AM
Header Buddies from Summit. SUM-G4772. But then you need to connect to your pipe....two joints or weld.....
Steve O.
Motorvation is offline
post #6 of 6 (permalink) Old Apr 5th, 14, 11:11 AM
Reducers (whether they reduce or not) are a piece of cake to fabricate if there's a sourcing problem. I just made my own on my last exhaust iteration.
69ZL1 is offline
This Thread is more than 1968 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
