BBC headers hit steering shaft - Chevelle Tech
  • 1 Post By Kopfjaeger
post #1 of 14 (permalink) Old Jul 12th, 20, 12:55 PM Thread Starter
I have a stroked 454 in my 70 Chevelle, and I am running 2" headers. driver side header tube is banging up against the steering shaft, and I just can't settle for the ole "take a hammer to it" solution. is there ANY way to resolve this without having to beat the ***** out of my coated headers?? heads are brodix BB2's. thank you
SouthTexasBully is offline
post #2 of 14 (permalink) Old Jul 12th, 20, 1:09 PM
Gary
Re: BBC headers hit steering shaft
You can dimple the tube with a split in half piece of Pcv tubing. Around inch and a half works. Mite have to gently pry the shaft over to slide the piece and place and then with a long piece of 2 by 4 or brass drift pop the shaft so the PVC dimples the tube just enough for around .080 of clearance is what I would shoot for. That method makes a nice clean dimple in the right spot. It's either that or you're going to have to modify the tube
gnicholson is offline
post #3 of 14 (permalink) Old Jul 12th, 20, 1:13 PM Thread Starter
that's interesting. thank you for that. does anyone on this site fabricate headers that clear? just curious
post #4 of 14 (permalink) Old Jul 12th, 20, 4:31 PM
My 30 year old Hooker Comp. headers clear.
1970 SS396 Chevelle
468 ci, TH 400, 3:73 posi
SS468 is offline
post #5 of 14 (permalink) Old Jul 12th, 20, 5:01 PM Thread Starter
are they 1.5" primaries?
post #6 of 14 (permalink) Old Jul 12th, 20, 5:11 PM
One word, Lemons. Call Dan and he will make you a pair of headers that will fit and not hit anything. They are works of art! Seriously.
If your Brodie heads are raised port, he’ll factor that into it as well.
Lew540 likes this.
1967 SS 396 Chevelle
Formerly Bolero Red
Soon to be a 427 equipped Tahoe Turquoise head turner!
Kopfjaeger is online now
post #7 of 14 (permalink) Old Jul 12th, 20, 6:25 PM
Greg.
Consider Shimming the Steering Box to move the steering shaft away from the # 1 # 3 # 5 cylinder header tubes,
1 washer at the top front and 2 washers at the bottom front.
I had previously Dented a little any of the Header Tubes required
Hookers # 2455-1 HKR Ceramic Coated / OD 2" Tubes x 30" Long / 3.5" Collectors x 10" Long
Installed in Oct 2006 and do not show any signs of Rust or Coating peeling to date
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is offline
post #8 of 14 (permalink) Old Jul 12th, 20, 6:31 PM
blm
Well you pretty much have two choices. Either dent the headers or get a new set of headers. Lemons are top quality and will clear. Maybe some other brands will as well. Dent your existing and send them for recoating or get some Lemons.
blm is online now
post #9 of 14 (permalink) Old Jul 12th, 20, 6:56 PM Thread Starter
wow. thanks for all the knowledge and help!
post #10 of 14 (permalink) Old Jul 12th, 20, 8:08 PM
I put a spacer under the motor mount to lift the engine up just a little higher. Worked perfect.
SteveDeluxe300 is offline
post #11 of 14 (permalink) Old Jul 13th, 20, 10:07 AM
Why not move the shaft over? There's about 3/8ish clearance you can create by unbolting the column lower plate and moving it over which in turn moves the shaft over. yes things changes a few things but its cheaper than a 1500+ set of headers.
Marc S
71 SS 454 ELCO
Edelbrock Proflo4
TKO600
Strange 12bolt w/4.10
1971ss454Elco is offline
post #12 of 14 (permalink) Old Jul 13th, 20, 10:46 AM
blm
If you have to ding them it is possible to touch them up.
https://www.cerakote.com/?msclkid=f3...ontent=General
blm is online now
post #13 of 14 (permalink) Old Jul 13th, 20, 12:16 PM
Mine are 2” primaries.
1970 SS396 Chevelle
SS468 is offline
post #14 of 14 (permalink) Old Jul 17th, 20, 3:22 PM
Can you elaborate more on moving the column over. I must be over looking something as I have the same problem. Thanks
Zeus69modchevelle is offline
