71 Chevelle ZZ502 Headers Needed !! - Chevelle Tech
 2Likes
  • 1 Post By Ericnova72
  • 1 Post By sz0k30
post #1 of 4 (permalink) Old Jun 5th, 20, 11:06 AM Thread Starter
I need help, I've already returned two set of headers that wouldn't fit. Are there any recommendations for a header that will work on a 71 Chevelle that is lowered, with a ZZ502 motor, that will NOT break the bank. The ZZ502 has the "D" exhaust ports, (1 7/8" wide & 1 1/2" tall) will a round header flange work on a "D" port head ??
D Hardy is offline
post #2 of 4 (permalink) Old Jun 6th, 20, 6:06 PM
Re: 71 Chevelle ZZ502 Headers Needed !!
Yes, round square or oval will work on the D-port head. The thing to look for is not blocking the sides or the top of the port.
Entire port opening in the header being big enough to not block any of the D-port head opening....then it doesn't matter what shape the header port opening is.
Best would be an oval or round big enough that the bottom of the header port opening is below the D-port opening in the head, making a reversion dam along the bottom of the port to block backflow into the cylinder during the overlap period around TDC exhaust stroke when both valves are open..
D Hardy likes this.
Ericnova72 is online now
post #3 of 4 (permalink) Old Jun 7th, 20, 9:58 AM
Roman
ZZ502 crate engines have been around almost 20 years. Pretty much any BBC headers will fit. The problem I see is not The headers fitting the heads, but the headers sitting too low to the ground with the lowered chassis.
Kirk's67SS likes this.
sz0k30 is offline
post #4 of 4 (permalink) Old Jun 29th, 20, 12:45 PM
Call Sanderson Headers and tell them what you need (650) 583-6617 https://www.sandersonheaders.com/ If they don't have what you need in stock they could probably make a set for you.
The Geologist is offline
