Exhaust tip clamp - Chevelle Tech
 8Likes
post #1 of 16 (permalink) Old Feb 27th, 20, 9:22 AM Thread Starter
Exhaust tip clamp
Hey guys - I want to install factory exhaust tips on my 70 Chevelle. Can you recommend the best clamp to hold them in place? Its 2.5" tailpipe. Thank you!
Tonys451 is offline
post #2 of 16 (permalink) Old Feb 27th, 20, 11:35 AM
Ole
Re: Exhaust tip clamp
One I got them rotated correctly, I welded the tips onto my '69.
Saltherring is offline
post #3 of 16 (permalink) Old Mar 14th, 20, 4:13 PM Thread Starter
For anyone interested, I used a band clamp made by Walker, and they work great. Clamps super tight and very clean looking
71350SS, MarkP and hydro462 like this.
Tonys451 is offline
post #4 of 16 (permalink) Old Mar 21st, 20, 5:55 PM
Thanks for posting that I woukd have tacked them in place but the band clamps would allow me to move them if I had to.Do you remember the part number?
hydro462 likes this.
71 El Camino SS
406 SBC M21 3.31 12 bolt
71350SS is offline
post #5 of 16 (permalink) Old Mar 22nd, 20, 8:45 AM
autumngold
inline tube,SKU: INL11081.
1970 ls-5 numbers matching
marcrose is offline
post #6 of 16 (permalink) Old Mar 22nd, 20, 8:55 AM
I use zip screws. I don't like the look of a big clamp sticking out..
hydro462 is offline
post #7 of 16 (permalink) Old Mar 22nd, 20, 9:00 AM
I use stainless Walker band clamps all the way down my exhaust system. Before clamping, I get the pipes perfectly lined up and send a zip screw into them to keep the pipes in line. Then I wrap the joint with high temperature 3M tape to seal up the joint, then install the clamp..
Having air tight joints all the way down the exhaust system really makes the car sound great. Before doing this my Dynomax Super Turbos sounds dead and boring, after sealing up all the joints in the above manner my 454 sound GREAT!!! It has the nice vintage big block sound and really come alive when I drop the hammer...
hydro462 is offline
post #8 of 16 (permalink) Old Mar 22nd, 20, 11:18 AM
Josh
Do you have a part # for the Walker clamps? Thanks!
Cheveezy is offline
post #9 of 16 (permalink) Old Mar 23rd, 20, 7:14 AM
Sorry Josh, I don't have the number. I have a 2-1/2" mandrill exhaust and I use the lap joint clamp. They also make a butt joint clamp, these don't work on joints that are interconnected..
They also make a cheaper nonstainless clamp, I used the better stainless ones..
hydro462 is offline
post #10 of 16 (permalink) Old Mar 23rd, 20, 9:44 AM
I used these on y magnaflow kit. Work great. Put the bolt to the top and it virtually disappears.
RAIDER SS likes this.
67
70 (SOLD)
Alwhite00 is online now
post #11 of 16 (permalink) Old Mar 23rd, 20, 7:45 PM
Josh
No problem, I'll look for them, thanks!
Cheveezy is offline
post #12 of 16 (permalink) Old Mar 24th, 20, 7:59 AM
Same here, so I just install the U-bolts with the nuts on top. This way they don’t hang down in the back
Team Chevelle Member (20 years and counting...
72soft-top is online now
post #13 of 16 (permalink) Old Mar 25th, 20, 9:06 AM
Hydro- Do you have a part # for that 3M tape? I really like that idea.
CMCE is offline
post #14 of 16 (permalink) Old Mar 25th, 20, 10:10 AM
3M Glass Cloth tape #66..
https://www.ebay.com/itm/3M-69-Ultra...oAAOSwEYReQNcq
This stuff is very strong. Make sure you cut it with scissors, don't rip it.. It will last years.. Also make sure you run at least one zip screw into the pipe connection to keep the pipes from twisting. I usually run three. I run the screw in then back it out and cut the unusable part off to help the flow...
hydro462 is offline
post #15 of 16 (permalink) Old Mar 25th, 20, 11:08 AM
Thank You!!!
CMCE is offline
