Exhaust kits - Chevelle Tech
 13Likes
post #1 of 27 (permalink) Old Dec 15th, 19, 9:26 PM Thread Starter
Michael
Exhaust kits
Looking into the Flowmaster American thunder 64-66 A body with 40 series mufflers behind shorty headers. Has anyone used one of these type of kits? Looking for a some what quiet highway ride, more noise WOT. Any thoughts?
64 Chevelle
85 Monte Carlo SS
Mikes64 is offline
post #2 of 27 (permalink) Old Dec 15th, 19, 9:37 PM
Bruce
Re: Exhaust kits
Sort of, I got the 2.5 inch ID pre-bent, Mandrel bent Tail Pipes, Mufflers, Hangers, clamps, nut, bolts, and a 2.5 ID "X" Pipe piece and took them to a local Muffler Shop (the muffler guy is well respected in the area) and had them fabricate the head pipes and fully weld up the system. VERY NICE!
Our You Tube Vids:
NickeyChevelle is offline
post #3 of 27 (permalink) Old Dec 15th, 19, 9:47 PM
Re: Exhaust kits
The FM 40 series won't be highway quiet.An H pipe or X pipe will quiet that type of system down if you use the 40 series muffs.
Also for quieter muffs with louder WOT then you want the turbo type mufflers lot of people have them on their Chevelle's and ElCamino's.Some even complain they're too quiet (me included).There are lots of information on the subject of exhaust if you search.
Why did you choose shorty headers ?
https://www.chevelles.com/forums/360...ers-again.html
You should find some good info in this link,especially read post #16.
blue_69_malibu likes this.
71 El Camino SS
406 SBC M21 3.31 12 bolt
71350SS is offline
post #4 of 27 (permalink) Old Dec 15th, 19, 10:23 PM
Jon N.
Re: Exhaust kits
Want quiet with power? Dynomax.
Jon N.
dyno jonn is offline
post #5 of 27 (permalink) Old Dec 16th, 19, 12:31 AM
Re: Exhaust kits
X2 on why you want the shorty headers..the 40s are loud...period. On the highway, they drone and it seems like everything in the car vibrates. I switched to some welded UltraFlo mufflers and Iím a lot happier with them. If your set on Flowmasters, the longest 50 series should work also...
77 cruiser and NickeyChevelle like this.
72 SS 402/4 speed/Straub roller and a bunch of Duramaxes.....
jrkrace is offline
post #6 of 27 (permalink) Old Dec 16th, 19, 6:53 AM Thread Starter
Michael
Re: Exhaust kits
I probably pulled the trigger a little early on the shortyís, was worried about clearance with ground to trans cross member with a 2Ē drop. I probably would have been ok, but thatís a done deal. Going to look into the above recommendations. Any more are welcome.
64 Chevelle
85 Monte Carlo SS
Mikes64 is offline
post #7 of 27 (permalink) Old Dec 16th, 19, 1:12 PM
Re: Exhaust kits
The above advise is spot on. 40's will be loud period. You should consider Flowmaster kit #17107 if you want an H-pipe system, or Pypes kit SGA10 or SGA30 if you want an X-pipe or straight dual system. Flowmaster is aluminized steel, Pypes is 409 stainless. Either system is without mufflers, so you can use whatever offset/offset muffler you want. Flowmaster makes a 50 series muffler which is quieter and greatly reduces drone. There is a Delta50 and Super50 muffler- Super50 is quieter. Dynomax Super Turbo is a favorite and for good reason. They come in 3 lengths - 14", 16",& 20" so you can choose your sound level. No drone, high flow, and a beautiful muscle car sound.
https://classicmusclecarexhaust.com/...flers-flo17107
https://classicmusclecarexhaust.com/...s/a-body/pypes
https://classicmusclecarexhaust.com/...turbo-mufflers
spoffie1962 is offline
post #8 of 27 (permalink) Old Dec 16th, 19, 2:45 PM
rick
Re: Exhaust kits
I had FM 40's on a 96 ram 318 true 2.5" duals and were way too loud, went to a muffler shop and they added turbos behind the 40's and it sounded good, I should've had them remove the FM junk and put them on Clist to get some $ back, now 3" Pypes with X pipe & violators
shovelrick is offline
post #9 of 27 (permalink) Old Dec 16th, 19, 4:29 PM
Re: Exhaust kits
I'm sure those 3" Violators are whisper quiet!..lol
shovelrick likes this.
post #10 of 27 (permalink) Old Dec 16th, 19, 4:45 PM
rick
Re: Exhaust kits
I forgot to mention the Pypes exhaust is on the Chevelle lol and it's only real loud when you step on the loud pedal, but I also have bad hearing, I'd look into the Pypes SS system minus mufflers and go online to listen to different mufflers
post #11 of 27 (permalink) Old Dec 16th, 19, 9:24 PM
Mark
Re: Exhaust kits
Ok, I'll go against the majority, I have a SS flow master kit with an H-pipe and 40's that came with the kit, I'm also running Doug's full length headers. Before I had the back seat in and the interior completed I thought it was too loud, actually I liked it but my wife was not thrilled. I actually bought some FM 50's but once I completed the interior, including installing the back seat, the 40's are fine. I returned the 50's. I'm running a basically stock 396 convertible (rag top may reduce any droning) but I also applied both steps of the lizard skin and jute under the carpet. My wife and I did the Power Tour last year and sound was never a problem, pretty quite cruising, but sounds good when needed.
Mark
66 SS
berg1954 is offline
post #12 of 27 (permalink) Old Dec 17th, 19, 8:26 AM Thread Starter
Michael
Re: Exhaust kits
After a bit of research I'm leaning on the Pypes SGA10, I like the fact that they are stainless with a cross over as apposed to aluminized. I've also read that the Turbo mufflers tend to be a little quieter on the highway. I didn't mention that exhaust will be behind a 6.0L completely stock. I intend to put a lot of highway miles on this, will look at some videos to see what others sound like, Thanks for the links/advise.
64 Chevelle
85 Monte Carlo SS
Mikes64 is offline
post #13 of 27 (permalink) Old Dec 17th, 19, 10:17 AM
Re: Exhaust kits
Regretfully I abused my hearing all my life to the point of needing hearing aids and also suffer from severe tinnitus. I'm at the point in my life where I hate loud so I run Dynomax Super turbo mufflers on my 468, 2.5" from the headers back to the tailpipes turned down behind the rear bumper. They are reasonably quiet, sound mellow until you push the fun pedal down, and flow better than most mufflers out there.
oldcutlass is offline
post #14 of 27 (permalink) Old Dec 17th, 19, 11:34 AM
Oldscutlass,
which size Super Turbo did you use- 14”,16”,or 20”?
post #15 of 27 (permalink) Old Dec 17th, 19, 10:29 PM
Re: Exhaust kits
If those shorty's are from Summit or Jegs you could probably return them for a credit exchange to get some long tube headers.Summit stepped up big time for me when I had a year and a half yr old clutch set for a 10 spline when I needed 26 spline clutch.They gave me full credit for the 10 spline and then I paid for the leftover with a CC .Really great place to deal with,I bet Jegs would give similar treatment too.
71 El Camino SS
71350SS is offline
