Lemons/Power Master Issues - Chevelle Tech
post #1 of 3 (permalink) Old Jul 6th, 19, 11:49 AM Thread Starter
blm
Have a new set of Lemons on my new 496. Also have the 9540 Power Master starter that was recommended by Dan for my set up. Man is the starter tight to the headers. Cant get the nut off that holds the power wire off without unbolting and rotating the starter. Which I have to do because the headers have burnt through the fuseable link (AAW update kit) which also runs very close to the headers. Had better clearance with my Hedmans.
I have ordered a Mad Electrical kit a month ago but it has not arrived. So for time being just have to install a new fuseable link.
Cant be the only one in this boat. How did you remedy the situation? Will wrap the new link in header tape.
blm is offline
post #2 of 3 (permalink) Old Jul 6th, 19, 12:13 PM Thread Starter
blm
Re: Lemons/Power Master Issues
Well I just removed the fuseable link and its still good. But did have to unbolt starter to get it off.
blm is offline
post #3 of 3 (permalink) Old Jul 6th, 19, 1:24 PM
If you loosen the 2 front screws on the mounting block you can possibly clock the starter for more clearance.
oldcutlass is offline
