need help with heat issue in the cab please!!!!!! - Chevelle Tech
post #1 of 4 (permalink) Old Jul 4th, 19, 3:18 PM Thread Starter
so i have a 1981 camaro that is motor swapped with a 427 BBC an the car runs good and is solid however ive noticed that after driving at about 50-60 for awhile or just driving in genaral the driver side foot well heats up fast i know this is due to the headers warmming up how should i go about reflecting the heat so i can drive with out having my feet roasted????? (it is carb no blower or turbo..............yet)
Treyton75 is offline
post #2 of 4 (permalink) Old Jul 4th, 19, 4:07 PM
Al
Re: need help with heat issue in the cab please!!!!!!
Install a heat shield on the areas affected. A stand off sheetmetal heat shield in combination a ceramic type heat shield works well in these areas. You can also add insulation to the interior of the floors under the carpet. Many use a product like Dynomat $$$$'s or a similar insulation available at home depot $'s.
Check out some of this videos for ideas. https://www.youtube.com/results?sear...+car+interiors
Tarheel Chevelle likes this.
DUTCH MAX HEADWORK is offline
post #3 of 4 (permalink) Old Jul 4th, 19, 4:15 PM
Lightbulb Re: need help with heat issue in the cab please!!!!!!
Many NASCAR drivers from the Glory Days
simply laced on a pair of Wing Tips...
No need to fry them lil' piggies!
Visit Thermotech, DRE & similar manufacturers
of heat-abatement, reflective and insulative products for vehicles.
Tip: Lowe's & Home Depot offer similar materials for home use.
Substantially less expensive.
Tarheel Chevelle is offline
post #4 of 4 (permalink) Old Jul 14th, 19, 11:43 AM
Harry
If the headers are super hot and discoloring, then, the new motor could be running retarded and blowing gas into the headers. What is the timing ? If big cam, advance the initial timing which will help you close the throttle blades and reduce fuel at idle.
Harry
hjdca is offline
