Headers for 67 El Camino with 350 - Chevelle Tech
  • 1 Post By Geoff1200
post #1 of 6 (permalink) Old May 20th, 19, 1:51 PM Thread Starter
Any suggestions for headers for my 67?
It has a 350 in there, and i believe it was originally a big block car.
-Good fit, no denting and bending
-Able to change plus with them installed
-Good seal
-Would be nice if it had an O2 bung
anything else I'm not thinking of?
'67 El Camino
teamcurtis is offline
post #2 of 6 (permalink) Old May 21st, 19, 11:07 AM
Geoff
Re: Headers for 67 El Camino with 350
67 ElCamino owner, I went with Sanderson cast headers, very good fit and best of all, NO LEAKS! I don't even use a flange gasket. 02 sensor placement varies, a 4 wire self heating sensor should be down stream a bit, narrow band sensors are used closer to the collector. Plug changes are a NON issue. I will never go back to tube headers on a street car, the Sanderson units are good for 500 hp and ground clearance is great. Run 2.5" pipes w/H cross over and turbo style mufflers, my 327 with a 150 N2O shot ran 12's
teamcurtis likes this.
Geoff1200 is offline
post #3 of 6 (permalink) Old May 21st, 19, 11:59 AM Thread Starter
Geoff, do you have a link or a part #? Most of the sandersons i am seeing are tube headers.
Block hugger, shorty, full length?
edit...
Im assuming is these?
https://www.sandersonheaders.com/san...ategory_id=355
Whats the sound like? Lets be honest the sound is at least 50% of why I want them
'67 El Camino
post #4 of 6 (permalink) Old May 21st, 19, 12:03 PM
Any pictures of them installed? I'm still running slightly cleaned up original 1967 cast iron manifolds on my ZZ4. I don't know how much torque I'm leaving on the table, but I like how it sounds, and runs, plus I like how they literally will last forever.
Pioneer4x4 is online now
post #5 of 6 (permalink) Old May 21st, 19, 3:27 PM
Geoff
edit...
You found them! Sound wise, the ticking/clicking sound of tube headers is gone, depending on exhaust choice, should be no droning. They fit great and I had NO clearance issues and NO leaks. Can't post pictures, son has my car till July.
post #6 of 6 (permalink) Old Jul 18th, 19, 10:34 PM
I installed a set of Hedman 68298 on my '67 with 383. Fit very nicely; had to jack up drivers side a little, even on a lift. They cleared my clutch "Z" bar, and only two areas needed "modification"., but NO denting or banging. No O2 bung, but that's easy.
On drivers side, lower control arm, rear bushing,; had to grind about 1/4" inch from lower housing to get it right...slight grind, not a big deal.
Also, #5 plug clearance is tight; I used short plugs, Autolite #104; ground a little off plug top/tip so boot would clear header, about 1/4" again, and have no problems.
Passenger side fits, clears, no problem...drivers side had both issues, but not big deal. They don;t hang low but they are not even length: passenger side collector extends about 3-6" further back than drivers.
Check Amazon for deals..
540 Olds is offline
68 El Camino - 74 Nova, same headers? Richard/SIA Engine 3 May 8th, 13 9:08 PM
70 Chevelle sb 350 upgrade advice MDS or Headers? Rumsey70 Performance 10 Apr 24th, 13 8:48 AM
70 Chevelle sb 350 MSD or Headers next? Rumsey70 Bench Racing 8 Apr 23rd, 13 5:22 PM
headers for 70 el camino 70 camino 1999 -- 1 Apr 7th, 99 12:43 PM
