Clearance Question: Pipes & Control Arm Braces - Chevelle Tech
post #1 of 8 (permalink) Old Apr 19th, 19, 9:29 AM Thread Starter
I went back a few pages and didn't see anything addressing my question, so here we are.. lol
Car: 1965 so applies to 64-72 I'm guessing..
Are there clearance considerations for over the axle fitment when running the lower to upper control arm braces? I have the full UMI kit in back, uppers/lowers/braces and am also running a 2" drop spring from BMR.
I am wanting to use 3" and exit right behind the rear tire. I didn't pay real close attention when I took the old exhaust out, so I dont' remember the routing area and what kind of space is available.
90lxracer is offline
post #2 of 8 (permalink) Old Apr 19th, 19, 9:37 AM
Re: Clearance Question: Pipes & Control Arm Braces
I don't have the UMI kit and am at stock ride height, but am running 3". I kept the rear on jackstands so the suspension was "compressed" and made sure I could slip my hand around pipes / any obstruction when mounting them. Haven't had any problems.
If you're worried, pull the springs and run the rear through it's motions while watching clearance.
I am running poly engine and trans mount so there's little flex along with walker 36518 hangers, so the exhaust is pretty solid. You can bang on it with a closed fist and it barely moves.
*Jeff*
LQ4 / T56 Swap
Hotwire is offline
post #3 of 8 (permalink) Old Apr 19th, 19, 9:49 AM
Allen
I assume you are asking about the brand Pypes and not 3" pipes of another manufacture.
71 with Pypes 3" with braces and Tanks EFI tank. A little tight but no issues. My kit was for straight out the back (under rear bumper) so not sure it translates directly to a 65 as there are minor differences but a call to the folks at Pypes will verify.
Blown1932 is offline
post #4 of 8 (permalink) Old Apr 19th, 19, 9:58 AM
I have a 1967 chevelle with 3 inch torque tech exhaust to the bumper. I also have 2 inch lowering springs, UMI upper and lower control arms, sway bar and G.M. upper to lower control arm braces. I have no clearance issues.
67SCOTT is offline
post #5 of 8 (permalink) Old Apr 19th, 19, 9:59 AM
Kevin
You shouldn't have any issues. I have the braces and a 2.5" system and there is a ton of clearance. The only issue I had was my Hellwig swaybar mounts around the rear axle hit at full compression. After a little clearancing and readjusting, all is good.
"If you're not living on the edge, you're taking up too much space" - Jim Whittaker
AFR Eliminator 195's
Inglese 50mm 8 stack injection
FAST XFI Street
SC&C Stage II Plus suspension
Hotchkis/Hellwig sway bars
Tremec TKO 600
Chevy67 is offline
post #6 of 8 (permalink) Old Apr 19th, 19, 10:50 AM Thread Starter
I wasn't referring to any specific brand at all. Just looking for generalities.
Thanks for the responses!! Bring any and all experiences!!
I will be running the enegery suspension ploy mounts for both engine/trans. I am running a g-force crossmember for the 200r-4 trans.
The car is blown apart for paint.. so, engine/trans/full exhaust is out that's why I don't have a real frame of refernce for clearance.
post #7 of 8 (permalink) Old Apr 20th, 19, 3:21 PM
Marcus
No clearance problems on my 64 with edelbrock braces and flowmaster 3 exhaust pipe kit.
Chevelle Malibu ss 64
Th 400 Edge 9.5" converter
Malibu ss 64 is online now
post #8 of 8 (permalink) Old Aug 23rd, 19, 12:46 AM
George
On my 71 using the Pypes 2-1/2 kit, I couldnt run the tail pipes. I have the UMI upper / lower control arms /braces and BMR Extreme ARB. Had to go with turndowns at the rear axle...hate it, but thats what works....
'71 Malibu
355 [email protected]
125 [email protected]
100 shot [email protected]
Geo71 is offline
68 Upper Control Arm Question Pakman68 Brakes, Suspension & Steering 6 Oct 19th, 15 2:31 PM
Help with estimate for front suspension rebuild vikingshelmut Brakes, Suspension & Steering 8 Apr 24th, 15 5:18 PM
Control Arm Bolt Question RickH Brakes, Suspension & Steering 3 Jul 11th, 14 1:41 PM
Real world results question: rear control arm braces worth it? thunderstruck507 Pro Touring 20 Jan 30th, 13 4:16 PM
SPC Control Arm possible Clearance Issues jtwoods4 Pro Touring 7 Jan 15th, 13 8:29 PM
