Questions on 2.5" vs 3" Exhaust - Chevelle Tech
 70Likes
post #1 of 91 (permalink) Old Dec 3rd, 18, 3:47 AM Thread Starter
Rob
Did a search and didn't come up with much info.
Is there a basic rule of thumb for how much power a 2.5", 3", 3.5", etc, exhaust system will support?
Due to space limitations, I'd like to run a 2.5" exhaust system on my 67 Impala. The motor is a 496 making a peak HP of 528 and 566 torque and its all done by 5300 RPM. At my performance level, would it be worth it to run the 3" exhaust?
66rat is offline
post #2 of 91 (permalink) Old Dec 3rd, 18, 5:36 AM
Re: Questions on 2.5" vs 3" Exhaust
I have an 11 second street car that makes 500+ HP real HP at the crank and I run a 2.5" exhaust with manifolds.
So,IMHO and experience you will be fine. If you were over 550 HP I would say go 3" and have at least a 1 7/8 primary tube headers with a BBC
Alan F likes this.
mr 4 speed is offline
post #3 of 91 (permalink) Old Dec 3rd, 18, 6:52 AM
Nope. 2.5 is fine.
Ray
bracketchev1221 is offline
post #4 of 91 (permalink) Old Dec 3rd, 18, 8:02 AM
jeff
Did you see this ..sped up video. 2.5" vs 3" much more HP than you make.
Now if you get some crappy bent tubes I feel the 3" will win over the 2.5" even on a smaller HP engine.
Mandrel bends are a must have if you put a lot of bends in the system.
Local muffler shops around here kink the bends.
jeff swisher is offline
post #5 of 91 (permalink) Old Dec 3rd, 18, 8:06 AM
But you could be in the 10's.
bigmachd likes this.
*Jeff*
LQ4 / T56 Swap
Hotwire is offline
post #6 of 91 (permalink) Old Dec 3rd, 18, 8:15 AM
It does exactly what I built it for and has worked very well for 18 years.
I have no desire to run in the 10's with it.
It is certified 100% stock appearing and gets driven 180 miles round trip to the track. Run high 11's and drive home.No headers,no 3" exhaust,no steep gears,no high rise intake.No special carb.
My point is, the OP will be fine with a 2.5" exhaust.
post #7 of 91 (permalink) Old Dec 3rd, 18, 8:42 AM
Lew
You are on the edge how much gain would remain to be seen. You do have a big engine though. I think the flowmaster guide was around 500 hp you should begin to look at 3 inch. I agree with Mr. 4 Speed - 550 hp you should definitely look at 3 inch but as I said you also have a lot of cubic inches too. You could do a 3 inch back to the muffler and 2.5 over the axle as a compromise. Furthermore, you need a mandrel bend not the Midas muffler shop bend where a 2.5 inch is squished down to a very ugly 2 inch or less looking 90 / 180 degree bend (like Jeff said above).
427L88 and Kirk's67SS like this.
Lew540 is offline
post #8 of 91 (permalink) Old Dec 3rd, 18, 9:14 AM
I think the mathematical answer is to run 3" to the mufflers, and then 2.5" behind if that alleviates your space concerns. Or 3" torque tubes off the headers that cone down to 2.5" ID maybe as the front of the headpipes. The further back the EX gas gets, the cooler and less pressure it has. This allows smaller space for full flow.
That MotorTrend video speaks to mufflers only? Please keep in mind the above thermodynamic relationship then. By the time EX gases get to the muffs, 2.5" v 3" may be rather academic from a pressure /volume pov.
Kirk's67SS likes this.
post #9 of 91 (permalink) Old Dec 3rd, 18, 10:07 AM
Mark
I had a 383, maybe 450hp, when I changed from 2.5 to 3. I ran the car with and without the mufflers/tailpipes 1/4mi, and it lost 2mph with the 2.5 mufflers/tailpipes vs open but didn't lose anything through the mufflers/tailpipes with the 3. The mph didn't really improve much with the 3, but I got the performance of the open 2.5 with mufflers.
427L88 likes this.
MadmanMark is offline
post #10 of 91 (permalink) Old Dec 3rd, 18, 11:04 AM
The further back the EX gas gets, the cooler and less pressure it has. This allows smaller space for full flow..
Would love to see data that supports this claim.
An exhaust system has x volume of combustion gases being pumped into it at any given time. It moves along the tube at x velocity. A drop in tube diameter will increase velocity and increase pressure at the point of restriction.
I've never seen data that showed how much the gas actually cools from the header/manifold to the end of the tail pipe during a WOT pull or the resultant PSI drop. It may exist, i've never seen it.
427L88 and ChevelleFan70 like this.
1967 Chevelle Malibu 4 door
The 7.99 at 173mph pass:
8.02 at 171mph:
Calculated Risk is offline
post #11 of 91 (permalink) Old Dec 3rd, 18, 11:53 AM
I believe Jim Hand did a series of exhaust tests years ago that could be relevant.
427L88 likes this.
post #12 of 91 (permalink) Old Dec 3rd, 18, 12:53 PM
In a gas, pressure=temperature x a constant.
Lower the temp, the pressure drops. If you actually refrigerated the exhaust pipe, you could condense the exhaust to a liquid, and get away with a small tube with no pressure.
Also, there is no such thing as "backpressure" in an exhaust, only pressure. Increase the restriction, and the pressure increases in the system everywhere.
A good practical example of reducing diameter is your headers. I bet if you worked it out, the primaries flow about the same as a 5"=6" pipe all added up.
Pioneer4x4 is offline
post #13 of 91 (permalink) Old Dec 3rd, 18, 1:53 PM
Rick, I dont have the data, but got that first hand from Dr Gas, who claimed they did. I did NOT make it up just because I "beleive it" but was given that by a engineer at Dr Gas who claimed empirical data. It squares with what little I know about fluid dynamics - not much! They also referred be to the Hand testing, but unsure if that A/B testing showed anything about down stream pressure reduction as the gas cooled.
Anyway, after my post I tried to find those nice long "torque tubes" that an outfit called "Torque Tech" out of Ga used to sell. A long off collector extension that went from 3 to 2.5". None found. So the math may be academic, as I could not assemble a system "off the shelf" that went from 3" across 24-30" down to 2.5" into the mufflers anymore.
It does mean that 3" tails are totally academic at these levels tho, as the mufflers are also a heat sink as well as a pressure reducer. As so the engineers told me.
post #14 of 91 (permalink) Old Dec 3rd, 18, 6:24 PM
Lew
Many years ago I had a engine dynode 600 hp 468 in my Chevelle and had T400 trans 4.11 gear. I went to the drag strip the best I could muster was 112-113 mph at like 12.30. I had 2 inch headers and 3.5 inch collectors. At that time I had 2.5 inch mufflers and 2.5 inch pipes all the way back to bumper. The pipes over the axle were not the best and were no mandrel. So kind of let down about the performance - I decided to make one more run but open the headers up. So I moved the exhaust over and bolted each one side of the collector and tied it up . Well went down the track and car felt different got the time slip and WOW 11.7 at 118 (I think 5+ mph is like 70 hp). Well I went home and started working on an exhaust did a full 3 inch system and got the time with exhaust to within 1 mph and 1 tenth of open headers. The car could have gone faster with some better jetting and more consistent driving but the main thing here is all I did on last run was open the headers up. I blame myself and the 2.5 inch exhaust for holding the car back (in some areas who knows my 2.5 inch exhaust might have been 2 inch with the old muffler shop non-mandrel bend). The peak power was at 6,200 rpm and with the old exhaust it was almost like the car stop making power at 5,000 rpm. The following week, I will never forget leaving Speedy muffler with the 3 inch mandrel set up and trying car out it was a night and day difference you could tell by the way the car lifted up on a roll that something had changed dramatically. Anyway that's my exhaust story.
Lew540 is offline
post #15 of 91 (permalink) Old Dec 3rd, 18, 7:37 PM
The bends are CRITICAL!
Dan Orgill and jeff swisher like this.
