Let's see those restored stock engines - Page 3 - Chevelle Tech
 29Likes
post #31 of 42 (permalink) Old May 1st, 17, 2:53 AM
RANDY
Re: Let's see those restored stock engines
Sounds like I was close, very close !!!
Randy
GLHS60 is offline
post #32 of 42 (permalink) Old May 2nd, 17, 8:49 AM
Here an an old photo of my Dec 65, 396 L34. Pretty much original from radiator to bell housing and from carb to oil pan. Reproduction rubber parts, fuel line, and from air cleaner up. I will add a few more photos when I get the car back from the shop today.
Original 3419 carb, dizzy, coil, ignition system, starter, selonid, engine wiring excluding spark plug wires, PB boster and MC, PS pump and reserivor, fan blade & fan clutch, radiator, water pump, exhaust manifolds, and fuel pump.
Name:	Jim's 66 ss, taken may 26,06 001.jpg
ID:	440178   Click image for larger version
ID:	440322   Click image for larger version
ID:	440330   Click image for larger version
Cam, framer and 6667ss138 like this.
Jim_66SS is offline
post #33 of 42 (permalink) Old May 5th, 17, 3:32 PM
My '65 Chevy II engine is far from stock, but I tried real hard to give it an OEM-type appearance.
Cam likes this.
novadude is offline
post #34 of 42 (permalink) Old May 6th, 17, 12:42 PM
Tom Lloyd
What a nice clean look. Very slick.
Tom Lloyd
take my advice, I'm not using it.
floyd66 is offline
post #35 of 42 (permalink) Old May 7th, 17, 7:42 PM
KEITH
1967 396 / 325 h.p.
ID:	441594   Click image for larger version
ID:	441602   Click image for larger version
6667ss138 likes this.
Keith
1967 Chevelle SS 49,500 mile car under restoration. Heavily documented.
1965 Corvette 396 425 H.P. restored in 1986
1971 Chevelle SS 402, 3sp manual trans. 50,078 miles, purchased from widow of original owner. Some Documentation.
1986 Silverado Lowered 5in front and 7in in rear.
kiserk1 is offline
post #36 of 42 (permalink) Old May 13th, 17, 2:36 PM
Like the overspray Keith. just a question regarding the temp sending unit, was that silver cad?
Jim_66SS is offline
post #37 of 42 (permalink) Old May 13th, 17, 2:52 PM
KEITH
Yes, Silver Cad. not sure if it's 100% correct.
Keith
kiserk1 is offline
post #38 of 42 (permalink) Old May 18th, 17, 2:08 PM
Thanks. Appreciate it!
novadude is offline
post #39 of 42 (permalink) Old May 18th, 17, 8:07 PM
Lorne
Here is my LS6 just after we reset the body on the
chassis.
ID:	444434   Click image for larger version
ID:	444442   Click image for larger version
When the flag drops the bullsh1t stops!
63 Vette rdstr 327/4p sold in 80's
68 Z28 Camaro
70 LS6 454 Chevelle apart for refreshing
hiperf406 is offline
post #40 of 42 (permalink) Old Sep 13th, 17, 3:39 PM
Originally Posted by jeffschevelle View Post
This one might be interesting to some of you Ė
NOS silk-screened oil filter canister with NOS filter inside ...
Jeff,
Where did you get your oil filter canister silk-screen painted? It looks great -- much better than the decal I have on mine. Is the canister painted flat, satin, or semi-gloss black? Thank you.
All the best,
1964 Chevelle SS restoration project
Billrv7 is offline
post #41 of 42 (permalink) Old Sep 13th, 17, 8:58 PM
That's an NOS oil filter canister, meaning "new old stock", meaning a new GM part made way back then but for some reason never got used. So it has not been repainted or re-screened. The paint is not full flat, but it is closer to flat than semi-gloss.
If you want one very nicely restored, call Richard Fortier at 810-750-1472. They aren't cheap, but they are VERY nice and much more accurate than the stick on label that most places sell. His silk screen is actually crisper and nicer than the NOS pieces are. And you can specify which bolt head marking you want. He's a nice fellow too.
67since67 likes this.
jeffschevelle is offline
post #42 of 42 (permalink) Old Sep 13th, 17, 9:38 PM
Andy
Here is my L35 396/325hp JA coded original (vin stamped) engine for the chevelle backed with a heavy duty Muncie 3-speed. The block is the 854 396 late in the 69 build year.
Name:	engine compartment pass side.jpg
ID:	474618   Click image for larger version
Name:	engine compartment front.jpg
ID:	474626   Click image for larger version
Name:	engine compartment dvrs side.jpg
Andy
1969 Baltimore SS Chevelle
1969 Trim Tag Research (Ongoing)
More 1969 Chevelle data needed submit your info today
Contact:
Information Security enforced
TC# 3135
ACES# 08305
SS69Chevelle is offline
This Thread is more than 890 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
