70 gauge cluster ? - Chevelle Tech
post #1 of 26 (permalink) Old Jun 23rd, 14, 9:20 PM Thread Starter
Jason
70 gauge cluster ?
I have searched and could not find the answer to my question, so here goes, On the back of the gauge cluster between the metal housing and the white/green plastic housing should there be a foam seal?
When I turn my dash lights on they do not seem to be as bright as they should be, and when you look around the edge of the gauges you can see the light shining around the edges instead of all the light shining on the gauge. You can turn the headlight switch all the way up to as bright as they will go and still is not very bright on the tach or the clock. The speedometer is the only one that is bright.
Sorry it is so long and thanks in advance for all the answers!
jp68camaross is offline
post #2 of 26 (permalink) Old Jun 23rd, 14, 9:35 PM
Ray
Re: 70 gauge cluster ?
Are all your light bulbs working in the gauge cluster? I replace all of mine and it seemed to help. The old bulbs were not very bright.
This what mine looked liked after I put new bulbs in.
70 SS Chevelle Van Nuys Cal Built
shadowgray396 is offline
post #3 of 26 (permalink) Old Jun 23rd, 14, 10:44 PM Thread Starter
Jason
Shadowgray396, I have put new bulbs in and all of them look to be burning except the bulb on the amp gauge, which will not burn no matter how many new blubs I have tried.
The only gauge that is as bright as yours is my speedometer. I will try replacing the new bulbs with a different brand new bulb. Do you know if the bulbs should be the small bulbs or the bigger round bulbs?
Thanks for the quick reply!
post #4 of 26 (permalink) Old Jun 24th, 14, 1:01 AM
Steamy
I'm not sure what the factory bulb recommendation is for a '70, but if it's a 1895 2 candlepower, you can use a 1816 3 candlepower bulb for more light.
BillL
My Showroom
Ark68SS is offline
post #5 of 26 (permalink) Old Jun 24th, 14, 7:58 AM Thread Starter
Jason
Ark68SS, Thanks, I will check to see what bulb number I am using and see if I can use the 1816 3 candlepower bulb. Hopefully I have the wrong bulbs in.
post #6 of 26 (permalink) Old Jun 24th, 14, 8:34 AM
What bulbs are in yours?..is this normal brightness?..Mine seems to be dim
TC #0672
1972 SS 454 M22
"W " Code Midnight Bronze
Bandit1978 is offline
post #7 of 26 (permalink) Old Jun 24th, 14, 10:24 AM
70-72 clusters use 197 bulbs. A lot of times the sockets get a little green corrosion on the terminals that contact the bulbs and will not allow current through the bulb to light it. If you scrape the corrosion off the socket terminal, it will correct the problem.
BlueSS454 is offline
post #8 of 26 (permalink) Old Jun 24th, 14, 10:40 AM
Ray
Mine are the 194, I just checked. I did what Tom mention cleaned all my sockets with a fine emery cloth to polish the contacts.
post #9 of 26 (permalink) Old Jun 24th, 14, 12:44 PM
On both turn signals, the brake light and the high beam light there should be foam seals attached to the steel housing.
RealRed70 is online now
post #10 of 26 (permalink) Old Jun 24th, 14, 7:57 PM Thread Starter
Jason
Thanks for all the answers, and I had the entire cluster out and cleaned each of the terminals that hold the bulbs and then put a new printed circuit board on. I am getting ready to take dash pad off and make sure I have the right bulbs in the cluster.
The knowledge of the people on this site is great for everyone in the car hobby!!
post #11 of 26 (permalink) Old Jun 24th, 14, 8:15 PM
The key is A) new, correct bulbs B) thorough cleaning of all the assemblies and lens C) Verifying connections so there is not a voltage drop.
The internal paint is meant to reflect the light as well as give it the proper color hue. Lens material should be cleaned and polished on both the inside (soot develops) and the outside.
Do not try to use different bulbs. LEDs are okay, but there are mixed reviews since most LED retrofits don't give the same omni-directional light output.
194 Wedge lamps are used on full gauge cars. DO NOT use 168 lamps "because they are brighter". When you increase current (which your dimmer rheostat does not appreciate), you also increase the heat from power dissipated (your instrumentation assemblies don't appreciate that).
I encountered a nice original '70 SS with dummy light dash and it came with 1895 bulbs interestingly enough. Not sure if the '71 and '72 dummy SS assemblies also used the globular 1895's.
Another thing to think about when trying to use different bulbs is bulbs have different life ratings. Why put something in that will prematurely burn out compared to the proper # ?
Coppertop is offline
post #12 of 26 (permalink) Old Jun 24th, 14, 8:59 PM Thread Starter
Jason
Pulled the dash pad off and I have the 1895 bulbs in my dash. I was thinking I bought the same bulb that came out of mine, but not sure now.
So I guess I should try to find the 197 bulbs and replace them all again and see if makes it shine any better?
post #13 of 26 (permalink) Old Jun 24th, 14, 9:20 PM
Changing bulb styles won't change brightness. If you go with 194 (it's not 197) bulbs you will need all new socket assemblies, FYI
post #14 of 26 (permalink) Old Jun 24th, 14, 9:23 PM
Are all lamps indeed lit up?
Dimmer on headlamp knob rotated to full brightness? Fuse block clips corrosion free (especially the little stubby 4 amp fuse)??
post #15 of 26 (permalink) Old Jun 24th, 14, 9:26 PM Thread Starter
Jason
So is the correct bulb a 197 like ShadowGray396 said or a 194 like Coppertop said? And can either of these be bought at the local auto parts or do they have to be ordered online?
This Thread is more than 2030 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
