Correct posi-traction tag for 1970 Chevelle - Chevelle Tech
post #1 of 12 (permalink) Old Nov 20th, 12, 11:29 PM Thread Starter
Mark
Is the red, triangular shape "Positraction lubrication" tag on a 1970 Chevelle metal or plastic? Most of the reproduction tags available don't say what they're made of and those that do say they're plastic. Is that correct? Thanks!
Mark2Mac is offline
post #2 of 12 (permalink) Old Nov 21st, 12, 4:52 AM
Donnie
Re: Correct posi-traction tag for 1970 Chevelle
yes, its plastic.
70 SS 396 Chevelle SOLD!
69 SS L-78 Chevelle
79 Z-28
04 GMC 2500HD Dmax/Allison
15 Wells Cargo 24' autowagon
07 Cadillac DTS
ACES #4390
Donnie1 is offline
post #3 of 12 (permalink) Old Nov 21st, 12, 2:36 PM Thread Starter
Mark
Thank you very much for the info, Donnie. Have a happy and safe Thanksgiving!
Mark2Mac is offline
post #4 of 12 (permalink) Old Nov 22nd, 12, 12:19 PM
Mark,
The tag is indeed plastic, but 70's have Limited Slip wording, 69's say Positraction so be aware of that as both styles are reproduced. They are made from the same red plastic blank.
ls6ragtop is offline
post #5 of 12 (permalink) Old Nov 23rd, 12, 11:34 AM Thread Starter
Mark
Thanks, Chris, I wasn't aware of the different wording. I'll look for the correct one.
Mark2Mac is offline
post #6 of 12 (permalink) Old Nov 23rd, 12, 12:07 PM
I removed this from a CKK coded 1970 rearend years ago, that I had traded for. Wish I had kept the rear as well as the tag!
Name:	1970 up posi tag.jpg
Doug Garland is offline
post #7 of 12 (permalink) Old Nov 23rd, 12, 12:34 PM
That's the right one for 70. Thanks Doug for posting up the picture.
post #8 of 12 (permalink) Old Nov 23rd, 12, 12:40 PM
Ray
The tags I've seen don't read correctly
http://www.ss396.com/mm5/merchant.mv...uct_Code=FPT-1
70 SS Chevelle Van Nuys Cal Built
shadowgray396 is offline
post #9 of 12 (permalink) Old Nov 23rd, 12, 1:21 PM
Ray,
That's the 69 version. Both styles are available, you will probably have to look for it as it appears Ground Up only carries the one style. Be aware that Corvette tags look similar but the bolt hole is much larger to accomodate the larger drain plug used on Corvettes so a Corvette vendor is probably not the place to buy one from.
post #10 of 12 (permalink) Old Nov 23rd, 12, 10:17 PM
Ray
Thanks Chris, for the info. I see OPGI has them
Ray
post #11 of 12 (permalink) Old Nov 30th, 12, 5:17 PM Thread Starter
Mark
Thanks guys--all the info is very helpful.
Mark2Mac is offline
post #12 of 12 (permalink) Old Dec 3rd, 12, 9:10 PM
Lance
Pacecar Jeff has the '70 tag
http://broachbuster.com/id36.htm
ACES #08588
1970 Olds 442 Survivor
1997 SVT Cobra Convertible
smoke' em II is offline
This Thread is more than 2637 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
