66 & 67 rear frame reinforcement braces - Chevelle Tech
  • 1 Post By Pete 67
post #1 of 7 (permalink) Old May 24th, 20, 3:16 PM Thread Starter
Are they the same for both years? Are convertible and d 2 dr cp the same?
How do reproductions fit? Do you have to remove mufflers to install them?
Jim_66SS is offline
post #2 of 7 (permalink) Old May 25th, 20, 12:43 AM
Re: 66 & 67 rear frame reinforcement braces
Not sure about 66 vs 67, but coupe/convertible and El Camino are the 'same". My '66 was built in late April (04D), and I knew a guy that bought and parted out an 04C car (both Fremont cars), and while the braces looked basically the same, there were a few minor differences. Nothing functional, but some extra holes were round in one and oval on the other... I don't recall looking that closely at some other braces I had...
As for the R&R with mufflers, I couldn't say what works with factory mufflers… But I have never had a problem. They just need to fit over the end of the control arm bolts, so not like they need a lot of clearance...
I know the aftermarket tubular braces can require quite a bit more room to install...
TC #1366
Sold
Sold
1966_L78 is offline
post #3 of 7 (permalink) Old May 25th, 20, 12:31 PM Thread Starter
I looked over and examined my 66SS with original braces and Gardner exhaust system. My Malibu vert is the same except the exhaust system has been replaced by a cut an weld job. The mounting hangers are different and the mufflers sit a bit higher. I think the braces will fit; but might be tight. Fortunately I have a spare set of original hangers from my 66SS that should be usable and drop the current mufflers a bit to give me more room. Thanks
Jim_66SS is offline
post #4 of 7 (permalink) Old May 25th, 20, 1:06 PM
Bruce
I think there is plenty of clearance unless the mufflers are too high and too far to the outside. The stock hangers seem to do a good job of locating the mufflers. Here are a couple of photos of my 66 El Camino.
ID:	627878   Click image for larger version
ID:	627880   Click image for larger version
ID:	627882   Click image for larger version
66 El Camino 396/325HP 4-Spd
My Build Thread:
62 Corvette 327/360HP (original RF engine and Fuel Injection) (future restoration project)
66 Corvair My son's project. Small block, Powerglide, C5 differential and rear suspension
72 Chevelle wagon project
AZCamino is online now
post #5 of 7 (permalink) Old May 25th, 20, 2:34 PM
FYI, for anyone looking to add a set to their ride, do not buy the ones that Midway Musclecar sells. They are manufactured incorrectly & are unable to be bolted up. The angles of the ends are stamped wrong & won't slide into place. When I contacted them to address the issue, they told me to kick rocks.
Don B likes this.
64 2 door Wagon Build thread
67 2 door Sedan LS1 T56
Pete 67 is online now
post #6 of 7 (permalink) Old May 25th, 20, 2:47 PM Thread Starter
Thanks for the Photo's Bruce. Now all I have to do is find my old hangers.
Jim_66SS is offline
post #7 of 7 (permalink) Old May 25th, 20, 3:47 PM
Keith
the ones sold at auto parts store made by walker are almost a dead match for original ones. and as they should be as walker supplied them in the first place
Maryland Chevelle Club #682
keithb is offline
