1970 chevelle rear blower - Chevelle Tech
  • 1 Post By Jayhawk500
post #1 of 11 (permalink) Old May 17th, 20, 9:35 AM Thread Starter
lou
Send a message via AIM to roadster601
good morning all i replaced my rear windshield blower on my chevelle, in the wiring kit came the harness and a signal white with stripe wire does anyone know what its for its working good without it thanks guys....
lou
roadster601 is offline
post #2 of 11 (permalink) Old May 17th, 20, 11:01 AM
Re: 1970 chevelle rear blower
Its likely to wire the car if it didn't have the original wire. Since yours did, you don't need it.
Jayhawk500 is offline
post #3 of 11 (permalink) Old May 17th, 20, 12:14 PM Thread Starter
lou
i replaced a harness that was there it didn't have this wire cant find in the aim book
lou
post #4 of 11 (permalink) Old May 17th, 20, 6:18 PM
I'm guessing that the car originally came with the defogger blower. Correct?
So I'm confused. You say its working, But the harness you replaced didn't have the wire for the blower. So what is powering the blower? Originally (factory), there should have been a purple wire from the defogger switch that ran into the trunk along with the tail light harness. Power (orange wire) came from the fuse block with a separate plug into the ignition port. I'll see if I can find it in my AIM. If it's not in there, it may be in the Fisher Body book.
Take a picture of the blower and the wire connected to it.
post #5 of 11 (permalink) Old May 17th, 20, 7:12 PM
This is the only thing in the AIM for the rear window defogger. Its only the dash wiring. The rest must be in the Fisher Body manual. Sorry.
post #6 of 11 (permalink) Old May 18th, 20, 9:26 AM Thread Starter
lou
hey chris thanks for taking the time, the harness is as you say all ready to go but in the box was an extra wire white with a black strip to me it looks like a fuse wire the wire is wraped in a cloth jacket as to the vinyl jacket on the main harness..
lou
post #7 of 11 (permalink) Old May 18th, 20, 9:34 AM Thread Starter
lou
Chris here is the harness with the wire if this helps ty
# C-2488-107A
Brand: American Autowire
Units: EACH
lou
post #8 of 11 (permalink) Old May 18th, 20, 10:10 AM
The wire in the box would have been if the car wasn't already wired for the blower. If you have power from the fuse panel to the switch, and from the switch to the blower. The wire in the box isn't needed. The factory defogger blower wiring isn't normally in the wiring for the tail light harness. It's a stand alone wire.
Hope this makes sense.
roadster601 likes this.
post #9 of 11 (permalink) Old May 19th, 20, 9:32 AM Thread Starter
lou
sounds great to thanks Chris
lou
post #10 of 11 (permalink) Old May 19th, 20, 10:48 AM
I can't help with the wire color coding but the blower wire runs from the dash into the plastic sheath that runs under the driver's seat.
#4 on this diagram from the 1971 Fisher Body Service Manual.
Name:	body wire routing 1.jpg
ID:	627260   Click image for larger version
Name:	body wiring routing 2.jpg
LS1tech.com supermoderator.
How may I help you?
1999 Trans Am-500hp
paul bell is offline
post #11 of 11 (permalink) Old May 19th, 20, 2:31 PM Thread Starter
lou
looks good thanks very much be safe.....
lou
