'66 Knee knocker tach problem... - Chevelle Tech
 3Likes
  • 1 Post By 67since67
  • 1 Post By hydro462
  • 1 Post By 1966_L78
post #1 of 14 (permalink) Old May 6th, 20, 5:18 PM Thread Starter
Hi all,
My tach has been dead for a long time and I was thinking about getting a new one from one of the repop parts suppliers.
Today the tach was showing signs of life (must of read my mind about it's future trip to the garbage can...), so today cruising around I glanced down at it and it was reading 800rpm but really should have said 2400ish rpm but wouldn't go higher with more revs then sitting idling it read 400rpm when engine idles at 800-850rpm.
Hei has the MSD module with the built in rev limiter that they made 10-12 years ago also.
Any ideas?
Thanks,
D
Darren Trudeau is offline
post #2 of 14 (permalink) Old May 7th, 20, 12:47 AM Thread Starter
Re: '66 Knee knocker tach problem...
Hmmm I hoped/thought someone would have some idea what to do/look for.
post #3 of 14 (permalink) Old May 7th, 20, 1:33 AM
Bill Wente
DO NOT toss that OEM tach! It has value, even if not working.
Having it repaired or upgraded to modern electronics would be preferable to repop.
I have no experience with how HEI/MSD might affect an OEM tach??
davewho1 likes this.
A few '67s and a '66
67since67 is offline
post #4 of 14 (permalink) Old May 7th, 20, 8:01 AM
Frankly those tach's were very hard to read while in motion. I picked up a shift light and hid it under the dash, it lets me know the perfect time to shift...
boyd66k20 likes this.
hydro462 is offline
post #5 of 14 (permalink) Old May 17th, 20, 11:09 AM Thread Starter
I'm not really a racer but will play once in a while, just having it work would be nice.
there were a couple things that may have been wrong:
1) I switched from point to HEI a long time ago and cut the brown wire to remove the loop terminal for the points coil
to add plug for the HEI in my youthful haste I just twisted the wires together and taped the up. The connection was
loose so I cut cut and re-stripped wires and soldered this time.
2) Also the bolt that holds the tach to the dash (which is the ground path was not very tight so snugged it up.
I haven't started the car since doing the above because a leaking pinion seal grew to something bigger and is taking the spotlight now.
Thx,
D
post #6 of 14 (permalink) Old May 17th, 20, 11:58 AM
I have an HEI, and an aftermarket knee knocker, all is well, and has been for many years.
66 Malibu
busterwivell is offline
post #7 of 14 (permalink) Old May 17th, 20, 2:58 PM
I used to have an HEI module (Dave's small body HEI conversion) and an OEM knee-knocker, never had a problem.
I was going to suggest checking all the connections...
If those don't help, perhaps it needs a "tach filter"... I think MSD makes one...
TC #1366
Sold
Sold
1966_L78 is offline
post #8 of 14 (permalink) Old May 17th, 20, 5:12 PM
Don't think the old tach has any voodoo electronics inside. Any good electronics guy could probably test and repair it for reasonable money. But I'd try a good ground and run a new signal wire first.
tom3 is offline
post #9 of 14 (permalink) Old May 17th, 20, 8:57 PM Thread Starter
One other thing I remembered just a moment ago when I was playing, there was a voltage difference between battery post to firewall bolt for engine strap was 12.6V and orange illumination light wire for tach and the tach housing ground was at 11.8V.
Probably a dozen places where the grounding is bad but any typical spots to check??
Thx,
D
post #10 of 14 (permalink) Old May 18th, 20, 7:38 AM
Funny, my 71 chevy truck has a factory in dash tach. The 454 (and prior 402) had HEI, and that tach has always been way off, way high. I don't know why, just put up with it for 24 years now.
66 Malibu
post #11 of 14 (permalink) Old May 19th, 20, 2:12 PM
On my original GM knee-knockers, there is an adjustment screw on the back (inside a hole in the housing). I once bought one that didn't work (so it was cheap). I hooked it up, and started turning the screw and it started working... Maybe your truck's tach has an adjustment screw?
427L88 likes this.
TC #1366
Sold
Sold
1966_L78 is offline
post #12 of 14 (permalink) Old May 19th, 20, 4:02 PM
Other than what Tony said, you might send it to someone like Instrument Repair Service.
post #13 of 14 (permalink) Old May 19th, 20, 6:05 PM Thread Starter
I'm still working on the diff, rear control arms, control arm bushings etc. so still no start since the diff repair started last week.
post #14 of 14 (permalink) Old May 20th, 20, 10:06 AM
I didn't check for that, years ago, I just looked to see if it might have some kind of 6 cyl/8 cyl switch or something.
66 Malibu
