66 crack in frame near control arm - Chevelle Tech
 9Likes
  • 2 Post By oldcutlass
  • 1 Post By johnny5
  • 4 Post By keithb
  • 1 Post By suntreemcanic
  • 1 Post By Steve R
post #1 of 8 (permalink) Old May 2nd, 20, 10:00 AM Thread Starter
john
I was hooking up the front brake lines and found this crack in the frame. Can this be repaired or do I need to get another frame.
johnny5 is offline
post #2 of 8 (permalink) Old May 2nd, 20, 12:37 PM
Re: 66 crack in frame near control arm
A good welder can repair that.
roadster601 and Steve R like this.
oldcutlass is offline
post #3 of 8 (permalink) Old May 2nd, 20, 2:11 PM Thread Starter
john
Thanks I was a little worried that it couldn't be fixed.
roadster601 likes this.
johnny5 is offline
post #4 of 8 (permalink) Old May 2nd, 20, 4:28 PM
Keith
drill a small hole at each end of the crack and weld it up
Maryland Chevelle Club #682
keithb is online now
post #5 of 8 (permalink) Old May 2nd, 20, 7:09 PM
lou
Send a message via AIM to roadster601
exactly, what i was going say good for you
lou
roadster601 is offline
post #6 of 8 (permalink) Old Jul 11th, 20, 6:44 PM
Greg
How did this repair go, I have a similar crack now the debate new frame or welder up
Life is too short for caring about every bodies else's stuff
Grock-co is offline
post #7 of 8 (permalink) Old Jul 15th, 20, 1:08 AM
Vern
Drilling a hole in each end of the crack is great advise but also vee out the crack to provide a stronger weld.
68-13427 likes this.
suntreemcanic is offline
post #8 of 8 (permalink) Old Jul 15th, 20, 5:51 AM
If you aren’t worried about looks, after you weld the crack you can install a plate over it. I had similar cracks on the frame of a 67 Chevelle, after we welded the crack we installed a plated on top with several holes drilled in it. We welded the perimeter and plug welded the holes.
Steve R
Steve R is online now
