66 outside drivers mirror template - Chevelle Tech
 3Likes
post #1 of 19 (permalink) Old Jan 21st, 20, 2:13 PM Thread Starter
Trying to clear up my mirror placement. I donít see anything in the AIM. When and where were the outside door mirror installed?
The reason I ask is because the mirror on the 66 I just got is kind of installed in the wrong location according to a mirror templates I have seem. Maybe it was installed after a long weekend. Anyway here is a photo. All indications are that itís the origional door. Maybe a new outside skin was installed; but if so it was a long time ago with original spot-welds, seam sealer, and type of insulation. But Iíve learned to never say never.
Here is a photo from inside the door panel, I think the location is about 3/4Ē to low. Take a look and tell me what you think.
ID:	614174   Click image for larger version
ID:	614176   Click image for larger version
Jim_66SS is offline
post #2 of 19 (permalink) Old Jan 21st, 20, 2:42 PM
Troy
re: 66 outside drivers mirror template
I would say the holes in the brace above the screws are the original mounting holes. The large hole is for a remote controlled mirror cables.
66 CHEVELLE
senna is offline
post #3 of 19 (permalink) Old Jan 21st, 20, 3:30 PM Thread Starter
Re: 66 outside drivers mirror template
That was my thought. But I think this was done at the factory unless a new skin was put on a long time ago. I wonder why the outer skin on the original door or skin was not pre-drilled. Or maybe it was and the hole were bonded shut, doesn't look like the hole in the reinforcement piece were ever used.
Can the current holes be welded shut and new holes made where they should be?
Jim_66SS is offline
post #4 of 19 (permalink) Old Jan 21st, 20, 6:24 PM
Keith
I would think the holes for the standard mirror was in the die that stamped the door skin for fisher body
Maryland Chevelle Club #682
keithb is offline
post #5 of 19 (permalink) Old Jan 21st, 20, 6:53 PM Thread Starter
My thought also; but why so far off unless the holes were damaged and they decided to weld shut and drill new hole. But at the time this would have been done I would have thought they just filled the holes with some kind of plastic filler.
Jim_66SS is offline
post #6 of 19 (permalink) Old Jan 21st, 20, 7:55 PM
Keith
Are you sure the door skin is original
keithb is offline
post #7 of 19 (permalink) Old Jan 21st, 20, 8:06 PM Thread Starter
I am never positive about anything; but everything about the door says it came from the factory. All physical signs point to original. Every nut and bolt Ive found looks original except the top, front and rear seat upholster, convertible top, and carpet. And of course some hoses and belts.
Passenger doors were not drilled for mirror; but have the backing plate. I would think that when the drivers door skin was made with the backing plate was applied the doors, inner core they would have drilled the holes. Mistakes have been made along the line before.
Jim_66SS is offline
post #8 of 19 (permalink) Old Jan 21st, 20, 8:09 PM
Keith
I know in a older post Jelf Helms outlined the differences of all the doors.
keithb is offline
post #9 of 19 (permalink) Old Jan 21st, 20, 8:16 PM Thread Starter
I remember something about that, door lock, some shapes of inner part. etc.
In that post I don't think I saw anything about mirrors. Maybe that was in a different post.
Jim_66SS is offline
post #10 of 19 (permalink) Old Jan 21st, 20, 8:38 PM
Keith
Hopefully he will see this a chime in. I guess at this point you donít have the door down to bare steel to see whatís hiding do you.
keithb is offline
post #11 of 19 (permalink) Old Jan 21st, 20, 10:58 PM Thread Starter
No, I am dealing with some other projects; but wanted to find out so that I can get that taken care of along with some other issues.
Jim_66SS is offline
post #12 of 19 (permalink) Old Jan 22nd, 20, 8:18 AM
Don
I don't have my AIM handy,it's @ my shop but if I remember correctly the accesory section in the rear of the AIM shows locations for right side mirror.
When I installed mine I compared those locations to the left side mirror and I'm pretty sure they were the same,correct me if I'm wrong.
Don B is offline
post #13 of 19 (permalink) Old Jan 22nd, 20, 8:56 AM Thread Starter
I am dealing with drivers mirror, not looking to install passenger side mirror.
Jim_66SS is offline
post #14 of 19 (permalink) Old Jan 22nd, 20, 3:23 PM
My OEM factory skin/door
ID:	614274   Click image for larger version
Blue 69 is offline
post #15 of 19 (permalink) Old Jan 22nd, 20, 3:49 PM Thread Starter
That first photo of the inside looks just like mine except the two holes are down lower. Another member has just PM me that his drivers mirror is also installed like mine. His is a 67 chevelle and in the restoration process has moved his mirror up. Mine is a late Nov of 65 Kansas City build. Just recently saw a door just exactly like yours at our Chevelle Club meeting here in Mpls, mn.
Jim_66SS is offline
