1969 396/375 idle stop solenoid - Chevelle Tech
  • 1 Post By Don's 69 SS
post #1 of 15 (permalink) Old Nov 14th, 19, 12:32 PM Thread Starter
Don
Looking for any information, parts numbers and or photos of the "idle stop solenoid" used on the 1969 396/375 hp engine.
Thanks in advance
Don's 69 SS is offline
post #2 of 15 (permalink) Old Nov 14th, 19, 3:30 PM
Re: 1969 396/375 idle stop solenoid
Holley carb or Q-Jet?
Jayhawk500 is offline
post #3 of 15 (permalink) Old Nov 14th, 19, 3:41 PM
Thanks in advance
Those did not come on the 396/375 HP L78 engines
mr 4 speed is offline
post #4 of 15 (permalink) Old Nov 14th, 19, 5:36 PM
Bruce
The idle stop solenoid was used on the 396/375 w/ Holley Carb when equiped with the TH400 (not with a manual transmission). Also on the 427/425 and TH400.
The bracket is made of pure unobtanium -- try eBay and be prepared to pay several hundred dollars for one. I looked on eBay - none shown.
The solenoid is scarce, to the tune of $150.00 on eBay. P/N: 1114421 (edit: I see a service replacement solenoid on eBay for 60 + 8 shipping. That is a steal).
Edit: Chicage Corvette Supply has the 2 piece Bracket, Screw, and Solenoid for $1,795.00.
Our You Tube Vids:
NickeyChevelle is offline
post #5 of 15 (permalink) Old Nov 14th, 19, 6:10 PM
Bruce
Never mind about CCS, that price was for the 3 duce setup.
Our You Tube Vids:
post #6 of 15 (permalink) Old Nov 14th, 19, 6:10 PM
Jon
You can get a reproduction bracket from one of the corvette parts dealers. I am not sure who i got mine from, but the price wasn't too bad. Especially compared to the original that I bought.
1972 Chevelle SS 454 "W" code
JChilders is offline
post #7 of 15 (permalink) Old Nov 15th, 19, 12:59 PM
Bruce
The anti-dieseling "Bracket" is P/N: 3959167. This bracket is attached to the intake manifold STUDS on the driver's side of the engine using two lock washers (P/N: 187119) and two nuts (P/N: 120376). NOTE that ALL L78/L72 engines came with the STUDS whether the engine got a manual trans or an automatic. According to my notes, a service replacement "Bracket" carried P/N: 3967426.
The "Solenoid Assembly" carried P/N: 1114418. The Solenoid was held in place by a "Clamp Assembly" with P/N: 3940917. The "Clamp Assembly" was bolted to the "Bracket" by "Bolt" P/N: 121887 and a washer P/N: 606404.
The Engine Harness offshoot was secured to the Valve Covers with "Clip" P/N: 3927330 that clips onto the rear Spark Plug Cables tower on the Valve Cover. A second "Clip," P/N: 367701 is inserted under the forward-most Valve Cover Attachment Bolt.
Our You Tube Vids:
post #8 of 15 (permalink) Old Nov 15th, 19, 1:05 PM
Bruce
How about a link?
Our You Tube Vids:
post #9 of 15 (permalink) Old Nov 15th, 19, 1:32 PM
Bruce
The "Bracket" might be on the 'Bu, if it is then there won't be a picture until spring. Sorry.
ID:	608122   Click image for larger version
ID:	608124   Click image for larger version
ID:	608126   Click image for larger version
Our You Tube Vids:
post #10 of 15 (permalink) Old Nov 16th, 19, 9:28 AM Thread Starter
Don
Bruce, I do have the "solenoid" & my wiring harness has the connection for one, but I have never seen one. I also have a very complete "67 three deuce" set up that came with my car for an "extra" $50!!! I paid $1850 for the car back in the day, took me two weeks too decide if I wanted to spend the extra $50 !!! Thanks for info, If anyone has photos of the unit as it's mounted, I would appreciate seeing them & the search continues!
Thanks again
Don
post #11 of 15 (permalink) Old Nov 16th, 19, 9:36 AM Thread Starter
Don
Chris, the carb on a 396/375HP is a Holley, Q-jets were used on the 325/HP & 350/ HP's. Mr. 4 Speed my car is a Turbo- 400. so it is supposed to have the solenoid, it's my understanding manual trans did not get the solenoid?
Thanks for your input
post #12 of 15 (permalink) Old Nov 16th, 19, 11:47 AM
Jon N.
Thanks again
Don
Wanna double or maybe even triple your money in that 3x2's set-up?
Jon N.
dyno jonn is online now
post #13 of 15 (permalink) Old Nov 16th, 19, 4:57 PM
Bruce
Our You Tube Vids:
post #14 of 15 (permalink) Old Nov 17th, 19, 7:45 PM Thread Starter
Don
Dyno Jonn, Thanks for the offer, but I better hang on to the 3 x2 setup for now. I kinda would like to try it out my car??
Thanks again.
dyno jonn likes this.
post #15 of 15 (permalink) Old Nov 17th, 19, 8:14 PM Thread Starter
Don
Bruce, thanks for the page from the assembly manual!
Greatly appreciated
