1970 chevelle ss speakers - Chevelle Tech
 11Likes
post #1 of 24 (permalink) Old Nov 12th, 19, 8:36 AM Thread Starter
lou
Send a message via AIM to roadster601
hey all, on my 70 chevelle ss i installed a AM/FM mono radio all tested a ready to go, hook it all up nothing. has power good ground there is only one plug as the am/radio how about the antenna, so here is the questions where does all the speaker wires junction, there are 3 speakers 2 in the dash one rear right rear. are they up is it in the harness are the grounds separate are the main speaker separate, is it a 3 way connector??? any help would be great im going to look in the aim book and fisher book i figured this is easier again thanks
lou
roadster601 is offline
post #2 of 24 (permalink) Old Nov 12th, 19, 9:21 AM
Re: 1970 chevelle ss speakers
Does your radio have the fader for the rear speaker? it would be on the shaft on the right side of the radio. Start with finding this out first. Does you radio have a speaker wire harness. The rear fader wire plug hook into this harness.
roadster601 likes this.
RealRed70 is offline
post #3 of 24 (permalink) Old Nov 12th, 19, 9:26 AM
If you do not have the proper harness, I would suggest you go to ebay and get the correct one. I see these on there quite often.
post #4 of 24 (permalink) Old Nov 12th, 19, 9:30 AM Thread Starter
lou
hey Dan thanks for getting back, thats my question is the harness separate for the speakers where would it be located taped in the main harness separate theirs power good ground nothing, how can the antenna wire be tested there nothing not even a hum
the radio is just been restored its a one year only radio
lou
post #5 of 24 (permalink) Old Nov 12th, 19, 10:12 AM
Proper impedance for those speakers is also important. Probably 8-10 ohms.
Most modern speakers are much lower impedance which will be tough on the final power transistor in your radio. It'll flow too much amperage through the back end of the radio because low impedance looks too much like a circuit short.
roadster601 and hydro462 like this.
B52bombardier1 is offline
post #6 of 24 (permalink) Old Nov 12th, 19, 1:10 PM
Just some trivia: If you DO NOT have a ( speaker LOAD) on the ( 1970-O.E.M.) radio and you turn it up while it is on, You will FRY the radio.................., If the out put is 8-10 ohms, Yes you can go higher, BUT you cannot go LOWER !
A 16 ohm speaker will work on a 10 ohm radio. The old style transistor radios are easy to COOK!
Series & Parallel speaker wiring is VERY important.
Robinls5 is offline
post #7 of 24 (permalink) Old Nov 12th, 19, 4:58 PM
I should have a harness here that I can take a picture of tomorrow for you. It is a separate harness from the dash harness.
post #8 of 24 (permalink) Old Nov 12th, 19, 6:53 PM Thread Starter
lou
hey Dan sure Ty
lou
post #9 of 24 (permalink) Old Nov 12th, 19, 7:00 PM Thread Starter
lou
hear is another question i tried as most suggested to turn radio on no thump move the fader its on the left side on this volumn radio knob 70 chevelles are one of a kind so i been told. radio has power, radio light, yes its separate i thought the speakers but all 3 are bad really?, i ordered the antenna lead wire form windshield to radio maybe its bad, a reason why i say this the am radio never worked either............ so any thoughts Ty all
lou
post #10 of 24 (permalink) Old Nov 12th, 19, 9:00 PM
My AM-only radio has pitifully bad reception inside of a building using my windshield antenna. Once outside, I can pick up several local stations and maybe 1-2 further away that are clear enough to be worthy of their own preset. Night time generally brings more but weaker choices because most of these stations go to lower transmit wattage at night. Propagation of signals is also somewhat better in this band at night.
post #11 of 24 (permalink) Old Nov 12th, 19, 9:36 PM
AM/FM mono use a center mounted front speaker. Stereo units use two front speakers. Not sure if a factory front stereo harness will work with a mono radio.
25C 70 is offline
post #12 of 24 (permalink) Old Nov 12th, 19, 9:42 PM Thread Starter
lou
Dave my chevelle SS has two dash mounted original speakers and one right rear original speaker
lou
post #13 of 24 (permalink) Old Nov 12th, 19, 9:56 PM
My original mono AM/FM use one center front and one pass side rear speaker. The radio has a fader. Rear speaker is listed separate on my build sheet. Was you car originally equipped with stereo unit?
25C 70 is offline
post #14 of 24 (permalink) Old Nov 13th, 19, 9:24 AM
If his car has A/C it will have two speakers in front even though it is a mono radio. It will also have the one in the rear. The A/C center vent is in the same location as where a center speaker would be. You can not have A/C and a center speaker.
post #15 of 24 (permalink) Old Nov 13th, 19, 9:57 AM Thread Starter
lou
yes dan it does have A/C ty
lou
