Trunk drain plugs - Chevelle Tech
 8Likes
  • 1 Post By Cam
  • 3 Post By Rich-L79
  • 1 Post By 69SS454
  • 1 Post By NickeyChevelle
  • 1 Post By jeffschevelle
  • 1 Post By paul bell
post #1 of 8 (permalink) Old Nov 8th, 19, 8:58 AM Thread Starter
Lou
Trunk drain plugs
Hi,
On my 65 Chevelle there are two rubber drain plugs in the trunk that I need to replace. Would anyone happen to know if these were installed before or after the splatter paint was applied. Minor detail but it can make a difference on the look. The existing were hard and brittle and did not appear to have any coating on them.
Thanks,
Lou
1943MB is offline
post #2 of 8 (permalink) Old Nov 8th, 19, 3:06 PM
Cam
Cameron Milne
Re: Trunk drain plugs
So many of these cars have been redone, finding an unmolested car to study is difficult. I believe the plugs were in place when the trunk was painted.
I have a '67 with original paint in the trunk (although I had to have the trunk side sections replaced). My rubber plugs seemed to have the remnants of some paint. My car was built in Oshawa with a body-coloured trunk, so possibly the painting process timing was done differently at other plants due to spatter paint. Also the rubber seems to shed the paint over time, leading us to see unpainted plugs or plugs stained with some kind of white paint or primer.
If I'm wrong, somebody please jump in and correct me. I'll bet Jeff Helms knows for sure.
1943MB likes this.
"The more you know,
TC Gold #120
Cam is offline
post #3 of 8 (permalink) Old Nov 8th, 19, 3:11 PM
Rich
If I had to guess, I'd say the rubber plugs were NOT painted. I've never seen any evidence of any kind of paint on plugs from a car that hasn't been messed with. The metal plugs YES are painted, rubber plugs are not. That's been my observation. However, I will admit that most of the untouched cars I'm referring to were pretty rough. At the end of the day, those plugs are covered by the trunk mat anyway so leaving them bare rubber will never really be seen and if you find out later they should be painted they could very easily be touched up to have paint.
In general, I've never seen any original rubber or plastic plugs in one of these cars that appeared to be painted by the factory. And if you think about it, you wouldn't want a plug in place before painting as the plug would cover raw metal that would quickly corrode as the plug would help hold moisture against bare metal.
HKalin, boyd66k20 and 1943MB like this.
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
Rich-L79 is offline
post #4 of 8 (permalink) Old Nov 8th, 19, 3:36 PM
The cleaning dip would not drain too well if the drain plugs were installed. No one would touch a car from the time it gets dip cleaned until it comes out of the body line with paint on it. At least this is what I have witnessed in the current auto plants. I assume it would be similar in the 60's and 70's.
1943MB likes this.
69SS454 is online now
post #5 of 8 (permalink) Old Nov 8th, 19, 5:43 PM
Bruce
Originally Posted by 1943MB View Post
Hi,
Thanks,
Lou
Here's an interesting video from 1970 showing (jump ahead to 16:30) the painting process on a 1970 Monte Carlo. Maybe it will give you an answer...
Based on this 1970 video, I'd guess NO the plugs came later. When the painted body is dropped onto the frame those workers down in the pit are doing more then bolting in the body bolts, I'd assume that is when the plugs went in... At least in 1970.
1943MB likes this.
Our You Tube Vids:
NickeyChevelle is offline
post #6 of 8 (permalink) Old Nov 8th, 19, 8:36 PM
It depends on which plant the car was built at. Some of them put the rubber plugs in the trunk before spatter, others after spatter. Which plant was your car built at?
1943MB likes this.
Jeff Helms
-65 Z16 Survivor (Red/black/white int.) (
-65 SS Convertible (Red)
-66 SS L34/M20 Survivor Coupe (Aztec Bronze) - 'Vintage Legend' Certified (
jeffschevelle is offline
post #7 of 8 (permalink) Old Nov 8th, 19, 10:19 PM
Camaros had the seals installed after the primer was baked in before painting the body.
CRG Research Report - Camaro Assembly Process
1943MB likes this.
LS1tech.com supermoderator.
How may I help you?
1999 Trans Am-500hp
paul bell is offline
post #8 of 8 (permalink) Old Nov 9th, 19, 10:05 AM Thread Starter
Lou
The Atlanta,Ga. plant
1943MB is offline
