master cylinder - Chevelle Tech
 10Likes
post #1 of 25 (permalink) Old Oct 4th, 19, 8:20 PM Thread Starter
lou
Send a message via AIM to roadster601
master cylinder
hello all i have a 1970 chevelle SS trying to get the correct master cylinder for it, any ideas and where can i get one searched EBAY nothing, there is a aftermarket master in there now. had put a correct 11 inch booster in with delco moraine tag on side, pedal seemed low any ideas on pedal height when applied any help is good Ty
lou
roadster601 is online now
post #2 of 25 (permalink) Old Oct 4th, 19, 9:06 PM Thread Starter
lou
Re: master cylinder
Originally Posted by roadster601 View Post
hello all i have a 1970 chevelle ss trying to get the correct master cylinder for it, any ideas and where can i get one searched ebay nothing, there is a aftermarket master in there now. Had put a correct 11 inch booster in with delco moraine tag on side, pedal seemed low any ideas on pedal height when applied any help is good ty
is there a part # for the master ty
lou
post #3 of 25 (permalink) Old Oct 4th, 19, 9:07 PM
The 70 big block master cylinder is a one year only item. They are very rare and hard to find. Should you find one - there is a small machined area at the front on the MC. On this pad will be two BB in capital letters.
Should you find one - they are easily rebuilt
roadster601 likes this.
1970 Astro Blue SS396 L34
George Halpin is offline
post #4 of 25 (permalink) Old Oct 4th, 19, 9:18 PM
Re: master cylinder
The depth of the hole in the rear of the cylinder needs the correct length plunger. This can be different from year to year.
shovelrick and roadster601 like this.
25C 70 is offline
post #5 of 25 (permalink) Old Oct 5th, 19, 9:06 AM
Re: master cylinder
Part number 5470409 is cast into the bottom of the MC.
post #6 of 25 (permalink) Old Oct 7th, 19, 10:24 AM Thread Starter
lou
Re: master cylinder
hello i been reading the early chevelles my car Feb used round master with bleeders,later chevelles used the 409 which is rectangle what do i do, Ty again
lou
post #7 of 25 (permalink) Old Oct 7th, 19, 1:08 PM
Re: master cylinder
I would put back whatever MC is on there right now.BTW, what MC is on there right now ?
One other thing,are you sure you need a new MC ? If "pedal height" is your only concern with no leakage from the MC and pedal does not drop completely to the floor then maybe your problem is something else ?
Brake pedal height with a disc/drum system is largely dependent on the rear brakes being adjusted correctly.That includes the brake shoes and the parking brake cable adjustment.When was the last time you checked the rear brakes ?
71 El Camino SS
406 SBC M21 3.31 12 bolt
71350SS is online now
post #8 of 25 (permalink) Old Oct 7th, 19, 1:33 PM Thread Starter
lou
Re: master cylinder
i know
lou
post #9 of 25 (permalink) Old Oct 8th, 19, 7:58 PM Thread Starter
lou
Re: master cylinder
last week i checked rears all good fronts good as i asked i have read early 70 chevelles used a round master cylinder with bleeders am i correct, my car is a Feb car.pedal height is about 2 inches off the floor pedal depressed
the master that was on there was leaking by plunger, so the 409 master is a later master rectangular unit.
lou
post #10 of 25 (permalink) Old Oct 9th, 19, 1:20 PM Thread Starter
lou
Re: master cylinder
so for my 70 chevelle would you have the answer
lou
post #11 of 25 (permalink) Old Oct 9th, 19, 1:50 PM Thread Starter
lou
Re: master cylinder
hello again does anyone know whats correct for my 1970 SS Feb car round or rectangular master cylinder
lou
post #12 of 25 (permalink) Old Oct 9th, 19, 2:14 PM
Re: master cylinder
This looks correct. The price is reasonable.
https://www.camarocentral.com/1970_1...p/brc-432b.htm
70 LS5 convertible
12stones is online now
post #13 of 25 (permalink) Old Oct 9th, 19, 2:22 PM Thread Starter
lou
Re: master cylinder
my question is being a early chevelle would it use a round master
lou
post #14 of 25 (permalink) Old Oct 9th, 19, 2:27 PM
Re: master cylinder
https://www.chevelles.com/forums/35-...er-1970-a.html
https://www.google.com/search?q=corr...iw=864&bih=405
February car built in what plant?
David
davewho1 is offline
post #15 of 25 (permalink) Old Oct 9th, 19, 3:02 PM Thread Starter
lou
Re: master cylinder
Baltimore thanks dave
davewho1 likes this.
lou
