1970 chevelle SS cowl induction question - Chevelle Tech
 13Likes
  • 5 Post By LevonH
  • 4 Post By LevonH
  • 1 Post By mr 4 speed
  • 2 Post By LevonH
post #1 of 10 (permalink) Old Aug 25th, 19, 3:39 PM Thread Starter
lou
Send a message via AIM to roadster601
hello all on the air cleaner on my cowl induction is the rubber seal,i see it says rear does the metal ring have to be secured with a screw or just lays there. thanks
lou
roadster601 is offline
post #2 of 10 (permalink) Old Aug 25th, 19, 7:28 PM
Levon
Re: 1970 chevelle SS cowl induction question
Just lays in place using the flanges to position it within the air cleaner base.
Levon Hovagimian
Team Chevelle #279
1966 427 Corvette SOLD
Priddis Greens, Ab. Canada
LevonH is offline
post #3 of 10 (permalink) Old Aug 25th, 19, 10:43 PM Thread Starter
lou
hello any pictures guys ty
lou
post #4 of 10 (permalink) Old Aug 25th, 19, 11:15 PM
Al
Name:	rs=w_600,h_600 (3)1971-72 Chevrolet Chevelle SS 396 454 Cowl Induction Air Cleaner.jpg
DUTCH MAX HEADWORK is offline
post #5 of 10 (permalink) Old Aug 25th, 19, 11:17 PM
Levon
Watch closely.
Google is your friend.
Levon Hovagimian
Team Chevelle #279
LevonH is offline
post #6 of 10 (permalink) Old Aug 25th, 19, 11:45 PM
Levon
If you ever want to see me cringe....take me to a car show where these are installed upside down. They look awful when not done correctly.
Levon Hovagimian
Team Chevelle #279
LevonH is offline
post #7 of 10 (permalink) Old Aug 26th, 19, 12:35 AM
Al
The backside of the flange has a raised up section with a U shaped notch. That sits over the rear clearance for the distributor. The flange just sits a top the filter base. The goofy cut out in the flange sits to the right rear to clear the a/c suitcase and vacuum resevoir on the firewall on a/c cars.
The attached picture is for Levon. Notice the rubber flange is mounted incorrectly. To install correctly you flip it inside out and upside down from how it's installed on this car. The ring or void in the top of this seal is the actual mounting point on the flange. The above video shows the process.
LeoP likes this.
post #8 of 10 (permalink) Old Aug 26th, 19, 9:13 AM Thread Starter
lou
Originally Posted by LevonH View Post
i have a question the metal ring has a notch in the rear is it to be screwed to the air cleaner, there isnt a place to center it on air cleaner.
good info on video Ty
lou
post #9 of 10 (permalink) Old Aug 26th, 19, 11:29 AM
There are no screws involved with the ring installation.
roadster601 likes this.
mr 4 speed is offline
post #10 of 10 (permalink) Old Aug 26th, 19, 3:34 PM
Levon
CRINGING as expected.
Levon Hovagimian
Team Chevelle #279
LevonH is offline
