1970 chevelle ss - Chevelle Tech
 3Likes
  • 1 Post By stanski
  • 1 Post By Dean
  • 1 Post By roadster601
post #1 of 8 (permalink) Old Aug 17th, 19, 9:21 AM Thread Starter
lou
Send a message via AIM to roadster601
1970 chevelle ss
hey all recently picked up a 70 chevelle SS, the former owner powered coated the hood hinges uck. i got 2 replacement hinges from ground up, the car has cowl induction hood with all this hood is an effort to keep open. after all that did cowl induction hoods have a heavy duty /stronger hood hinge spring if so where can i get 2 thanks....
lou
roadster601 is offline
post #2 of 8 (permalink) Old Aug 17th, 19, 9:47 AM
Greg
I prefer the weaker hinge springs, I have see a couple of Chevy trucks hoods bend because a little age on the hinges and heavy duty springs, with the leverage at the end of the hood. Something has to give and that something is usually the hood, why take the chance.
Life is too short for caring about every bodies else's stuff
Grock-co is offline
post #3 of 8 (permalink) Old Aug 17th, 19, 10:16 AM Thread Starter
lou
Re: 1970 chevelle ss
ok now so has anyone replaced hood springs safely
lou
post #4 of 8 (permalink) Old Aug 17th, 19, 11:50 AM
Michael
Yes. I've pried off my old springs with a BASD (Big @SS ScrewDriver). Easy to do. Close the hinge so that there is minimal tension on the spring. Wrap the majority of it with a heavy towel, leaving one spring end exposed. Insert BASD between spring end coil and hinge hook and lever off.
Reverse is similar. You use the hinge hook as the support for your spring. Using the BASD like a lever, lift/open the spring and carefully slide it home over the BASD end and onto its hinge hook.
michael j (your mileage may vary.)
1970 Chevelle SS396 - "Elektra"
Canadian built true SS, L34, bucket seats, 4 speed, Posi, console, deep fathom blue with white interior, white vinyl top and white stripes.
1980 El Camino
229 V6, 200C Metric (soon to have a 200-4R)
michael j is offline
post #5 of 8 (permalink) Old Aug 17th, 19, 2:49 PM
Stan
I use spikes (nails). To remove, when spring is extended, stick enough nails between the coils to keep spring extended then close hood and spring falls out. To put in new spring put in vice and bend it to spread coils and keep sticking in nails till it is long enough to install, then remove the nails.
michael j likes this.
stanski is offline
post #6 of 8 (permalink) Old Aug 17th, 19, 10:24 PM
Michael
Great tip, stanski!
1980 El Camino
post #7 of 8 (permalink) Old Aug 17th, 19, 10:57 PM
https://www.chevelles.com/forums/45-...d-springs.html
davewho1 likes this.
post #8 of 8 (permalink) Old Aug 18th, 19, 8:59 PM Thread Starter
lou
OK guys all done i held hood open all the way, i had made a bar out of a stock lug wrench,on either side on the hub cap end put 2 notches and pryed the spring off and on, too 5 minutes.
too all thanks
lou
