70 Chevelle ss ls6 454 Harrison radiator - Chevelle Tech
 2Likes
  • 1 Post By Robert Sargent Jr
  • 1 Post By michael j
post #1 of 13 (permalink) Old Aug 11th, 19, 2:30 PM Thread Starter
Somewhere along the way, before I rescued it, the radiator in this car disappeared. I'm trying to get it back to its original state, or as close as possible without completely breaking the bank. It is a 70 LS6 454 with m22 trans, 3:31 rear end, and no a/c (which should go without saying). I believe I need the Harrison BQ XJ IA 3 core radiator. Certainly a needle in a haystack, but are there any replicas out there? It seems there are a few four core versions, but the original in this car was definitely a three core.
Robert Sargent Jr is offline
post #2 of 13 (permalink) Old Aug 11th, 19, 2:59 PM
autumngold
Re: 70 Chevelle ss ls6 454 Harrison radiator
Keep an eye out on ebay.3 core was more common than 4.You can find the tank codes from time to time on used cores.,any rad shop can get you a core.The triangle slots in the mounting frame might not be there on the core but it will be close lookwise.Hope you have your fan shroud,they are hard to find also.
1970 ls-5 numbers matching
marcrose is offline
post #3 of 13 (permalink) Old Aug 11th, 19, 7:35 PM
I have an LS-5//M-22 with A/C. The tanks are coded " XJ " & " IF " & PA.
Its a four row rad.
Robinls5 is offline
post #4 of 13 (permalink) Old Aug 11th, 19, 8:55 PM
Levon
Here you go:
https://www.heartbeatcitycamaro.com/...-Transmission/
Levon Hovagimian
Team Chevelle #279
1966 427 Corvette SOLD
Priddis Greens, Ab. Canada
LevonH is offline
post #5 of 13 (permalink) Old Aug 13th, 19, 1:41 AM Thread Starter
Tried to order from Heartbeat Camaro. After they took my payment, I got a call about a week later that it was on backorder. When I asked the last time they had them in stock, the guy told me it was 2011. I graciously asked for a refund.
LeoP likes this.
post #6 of 13 (permalink) Old Aug 16th, 19, 5:38 PM
Michael
Not sure if you've found this yet [attached chart from chevellestuff.net], but it will help you confirm your research.
FWIW, I had searched for literally years for a "BE" 3-core rad with IA/XJ tanks. Early this year I finally hit on eBay with a unit needing recoring. I used Radiator Master in St Olaf, IA to do the recore work and I'm glad I did. They used a hi-efficiency 3-core that has the cooling ability of an old 4 core while maintaining the 3-core size. The massaged out dents and dings from the tanks and were even able to repair a few hairline cracks in the old tanks. I have yet to install/run the new rad, but it looks great!
Chuck did the work and can be found at: Radiator Repair in Iowa
ID:	600766   Click image for larger version
ID:	600772   Click image for larger version
ID:	600774   Click image for larger version
LeoP likes this.
michael j (your mileage may vary.)
1970 Chevelle SS396 - "Elektra"
Canadian built true SS, L34, bucket seats, 4 speed, Posi, console, deep fathom blue with white interior, white vinyl top and white stripes.
1980 El Camino
229 V6, 200C Metric (soon to have a 200-4R)
michael j is offline
post #7 of 13 (permalink) Old Aug 16th, 19, 7:42 PM
autumngold
I bought a four core made in usa core from them 6 months ago.Used my original side tanks and date codes.Core was an exact match right to the triangle cut outs.Not sure if they have a 3 core though.
marcrose is offline
post #8 of 13 (permalink) Old Aug 16th, 19, 9:24 PM
blm
There is a guy in upstate Michigan that restores Harrison rads and has for years. Bob???. Used to be a link for his service on the Alum a tech site but that is gone now as well. He may have what you need. There have been some threads about his Harrison service so a search might find his info.
blm is offline
post #9 of 13 (permalink) Old Aug 16th, 19, 10:16 PM
blm
The contact info for the guy in Michigan is in this thread. Post # 10
https://www.chevelles.com/forums/32-...ml#post9634834
blm is offline
post #10 of 13 (permalink) Old Aug 17th, 19, 12:35 AM
I just picked up an original Harrison for my 2 door wagon that I'd like to have recored. Can I ask what you paid to have yours done, including shipping?
Thanks!
64 2 door Wagon Build thread
67 2 door Sedan LS1 T56
Pete 67 is offline
post #11 of 13 (permalink) Old Aug 17th, 19, 3:51 AM
Good info^^^
_
Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in broadside, thoroughly used up, totally worn out and loudly proclaiming: "WOW! WHAT A RIDE!!"
Redmanf1 is offline
post #12 of 13 (permalink) Old Aug 17th, 19, 8:38 AM
Michael
The price to recore the rad (with the high efficiency 3 core vs 3 core with original cooling specs) with shipping back to me was roughly $650 ($590 coring + shipping). But don't forget that you need to get it to them first, and they'd prefer if you didn't hack it apart to make it fit for a cheaper shipping price.
I was EXTREMELY precise in what I wanted being as communicative as possible. I was told that these cores are readily available pre-fab (sans-tanks but including side panels) and they are the lion-share of the price. I even sent them the GM radiator specs I posted here from Chevelles.net to aid our discussion, and asked them to compare my rad with the specs with the new core for size. They suggested the more expensive high-efficiency core as a safety margin in case of future engine work being done, which I hadn't considered. It was about a $130 more expensive than the standard core, but very much worth the price/peace of mind in the long run. Appearance-wise, all the dimensions are the same, just more fin folds per inch per row. You'd be hard pressed to spot the difference.
I very much appreciate the work Chuck did. He massaged and repaired the old tanks, assembled the new core with tanks, than did a pressure test of the completed unit. During the test he found a number of small cracks in the very old and stressed tanks (possible freeze damage) and then disassembled everything to address/fix. Assembled again and re-pressure tested to assure the work was complete. Then he painted it.
Chuck and Judy are good people. Judy will be your contact to discuss the job with, and Chuck is ex-Navy. Small shop. Support mom and pop!
1980 El Camino
post #13 of 13 (permalink) Old Aug 18th, 19, 3:40 AM
Thanks for the thorough reply!
Pete 67 is offline
