66 SS hood - Chevelle Tech
 5Likes
  • 1 Post By DaleM
  • 1 Post By cheveslakr
  • 3 Post By jeffschevelle
post #1 of 12 (permalink) Old Jul 31st, 19, 4:27 PM Thread Starter
66 SS hood
Is there a part number on a original SS hood? Looking to buy a original hood but need to know what to look for to make sure its not a repop. Thanks
SS66Project19 is offline
post #2 of 12 (permalink) Old Jul 31st, 19, 5:21 PM
Keith
Re: 66 SS hood
no part number. there was three designs of the hood and the repro follows the third one. the easiest way is on the front edge. by looking on the side originals has a lip about 3/16 where repro does not
Maryland Chevelle Club #682
keithb is offline
post #3 of 12 (permalink) Old Aug 10th, 19, 10:46 AM
Dale
Re: 66 SS hood
I'm aware of two designs. First is part number 3874746 for the early hoods with 5 cutouts on the underside prior to Jan 20. Second design hood is part number 3896559 with 3 cutouts on the underside. Some plants may have gotten the later style hood earlier than Jan 20 and some may still have had inventory of the early hoods
ID:	600122   Click image for larger version
Pete 67 likes this.
TC Gold #92 ~ August 1998
* Build Sheet Data Collection
* Author:
DaleM is offline
post #4 of 12 (permalink) Old Aug 10th, 19, 4:31 PM
Keith
Re: 66 SS hood
Dale I recall from way back when Mike Crown showed a 1st design hood that had the hood louvers bolted down directly to the top of the hood skin. for the second design they recessed them.
keithb is offline
post #5 of 12 (permalink) Old Aug 10th, 19, 6:54 PM
Dale
Re: 66 SS hood
You are correct, Keith. Blue is early, red is late.
ID:	600160   Click image for larger version
* Author:
DaleM is offline
post #6 of 12 (permalink) Old Aug 10th, 19, 9:51 PM
Keith
Re: 66 SS hood
Dale wasn't the second design have the reassessed louvers with five cut outs and the third design the three
keithb is offline
post #7 of 12 (permalink) Old Aug 10th, 19, 11:43 PM
Dale
Re: 66 SS hood
Not aware of a third design but the same two underhood designs were applied to the other 2 hoods, one for 300/300 Deluxe and one for the Malibu.
* Author:
DaleM is offline
post #8 of 12 (permalink) Old Aug 11th, 19, 12:11 AM
jerry
Re: 66 SS hood
If I may.....I believe Keith is thinking the first design was the 5 cutouts with non-recessed louvers, the second design had the recessed louvers and still had 5 cutouts, while a third design had the recessed louvers and 3 cutouts. that's always been my assumption, but hadn't ever researched it.
keithb likes this.
cheveslakr is offline
post #9 of 12 (permalink) Old Aug 11th, 19, 3:51 AM
Smile Re: 66 SS hood
A few things that may be of interest:
https://www.chevelles.com/forums/35-...966-hoods.html
https://www.chevelles.com/forums/35-...libu-hood.html (make sure you read the whole thread )
David
davewho1 is offline
post #10 of 12 (permalink) Old Aug 13th, 19, 8:16 PM
Re: 66 SS hood
There were only two versions:
1. The 5-hole with holes for mounting the scoops (which holes apparently were a little smaller in measurement and a little shallower than the second design, which made the scoops stick up a little higher and made the indention in the hood skin less visible under the outer edge of the scoop); and
2. The 3-hole with holes for mounting the scoops (which holes apparently were a little larger in measurement and a little deeper than the first design, which allowed the scoop to sit "down" in the indention in the skin and resulted in the visible groove all the way around the scoop).
There was never a factory 66 SS hood with scoops mounted straight on top of a flat Malibu hood without scoop opening holes. Period. See the second link in Dave's post above for more details!
1966_L78, davewho1 and 67since67 like this.
Jeff Helms
-65 Z16 Survivor (Red/black/white int.) (
-65 SS Convertible (Red)
-66 SS L34/M20 Survivor Coupe (Aztec Bronze) - 'Vintage Legend' Certified (
jeffschevelle is offline
post #11 of 12 (permalink) Old Aug 14th, 19, 1:01 AM
Re: 66 SS hood
Spot on, not the only mistake by MC.
Jim_66SS is offline
post #12 of 12 (permalink) Old Aug 14th, 19, 1:56 AM
Re: 66 SS hood
When I was much younger, I mounted a set of SS scoops on a Malibu hood... I HAD to cut large rectangular holes in the hood, because the scoops actually protruded below the hood skin, so they would NOT sit on top of a Malibu hood... I also had to grind a small ridge (gasket retention?) around the bottom of each scoop... But with a limited budget, some extra scoops and a spare Malibu hood, I took on the challenge...
My other real SS hood at the time must have been "early", because the scoops were not recessed.
TC #1366
Sold
Sold
1966_L78 is offline
