1972 Big Block Starter Shield? - Chevelle Tech
post #1 of 17 (permalink) Old Jul 16th, 19, 5:21 PM Thread Starter
I am trying to verify if big blocks came with the starter heat shield in 1972. I do not see them shown in the AIM. Can anyone confirm for sure if they still had them in '72?
Kirby Demot
72 SS Convertible, 350 4speed
72 Heavy Chevy, original 402, 400 Turbo
72Conv is offline
post #2 of 17 (permalink) Old Jul 16th, 19, 7:30 PM
jerry
Re: 1972 Big Block Starter Shield?
Don't have a '72 AIM, but I can't imagine the logic of developing something necessary and then deciding to cancel it. It was an issue with big blocks. The problem I've got is a header tube that runs less than a finger's width around the solenoid, not allowing the use of the shield. The beauty of headers, is they heat up quick, and they cool down quick, but in the meantime the solenoid retains that heat and it remains to be seen if I'm going to have a problem.
I'd study the AIM a little closer and review each section under L34, LS5 and LS3.
cheveslakr is offline
post #3 of 17 (permalink) Old Jul 18th, 19, 9:17 AM Thread Starter
As I mentioned in my first post, I do not see any mention of the heat shield in the 72 AIM. I am curious if they are shown in the 70 or 71 AIM (I do not have either of those). Could someone with one of those manuals check?
Kirby Demot
72Conv is offline
post #4 of 17 (permalink) Old Jul 18th, 19, 10:19 PM
If it was a stock item, I would imagen that it would be part of the engine build up and not part of the chassis buildup.
I'll look at my 70 AIM tonight and report back later.
Jayhawk500 is offline
post #5 of 17 (permalink) Old Jul 18th, 19, 11:23 PM
jerry
Definitely not part of the engine assembly. Need to connect all the starter wiring first.
post #6 of 17 (permalink) Old Jul 19th, 19, 10:02 AM
Dale
70 AIM shows heat shield - #3954224
GM parts book shows same number (3954224) to fit the following and defines it as "Shield, solenoid (stainless steel)
69 All (396, 427) ( exc. T.H. 400)
70 All (396, 400, 454)
71 Camaro (400)
71 Chevelle w/Sp. H./Per (454)
TC Gold #92 ~ August 1998
* Build Sheet Data Collection
* Author:
DaleM is offline
post #7 of 17 (permalink) Old Jul 19th, 19, 4:09 PM
We are restoring a 72 LS5, I was told by someone who has a survivor car that it doesnt have one and he hasn't see one but I dont have documentation for this and I myself would like to know for sure. My customer want to get the car judged and I hope to have all the answers. Any help would be great. Thanks
carriage house resto is offline
post #8 of 17 (permalink) Old Jul 20th, 19, 12:08 PM
Dale, Were in the AIM did you find it? I looked through my book and couldn't find it.
Found this last night on the Bay. I personally think it's a bit overpriced for a piece of sheet metal.
https://www.ebay.com/itm/69-70-Camar...c7a7%7Ciid%3A1
post #9 of 17 (permalink) Old Jul 20th, 19, 12:55 PM
Dale
1970 AIM - UPC L34/LS3, sheet A10. Since it isn't shown in the 1972 AIM nor in the parts book, I wouldn't spend $1K for something designed for a 70.
* Author:
DaleM is offline
post #10 of 17 (permalink) Old Jul 20th, 19, 9:43 PM
Well, so it is. I even had the page dog eared. I'm with you...Not spending that kind of money. There's other options available to prevent the starter from getting heat soaked.
post #11 of 17 (permalink) Old Jul 20th, 19, 10:14 PM
Al
I think this is a repop of the same part number made in stainless steel. $62.00 I can't tell you if they came as original equipment on a 72 Chevelle.
https://www.rickscamaros.com/camaro-...1967-1969.html
"Manufactured in stainless steel as original in the USA. Technically correct reproduction starter heat shield found on all big blocks (GM# 3954224). For the demanding restorer."
DUTCH MAX HEADWORK is offline
post #12 of 17 (permalink) Old Jul 21st, 19, 1:36 AM
Al
Found another here for $38.00 but doesn't say stainless steel.
https://www.classicmuscle.com/bb-correct
post #13 of 17 (permalink) Old Jul 21st, 19, 1:41 AM
Al
Is 6485252 shown in the 72 parts book? GM Wiki shows 6485244 discontinued, use 6485252.
It may be listed in the chassis manual.
post #14 of 17 (permalink) Old Jul 21st, 19, 4:07 AM
The part number shown for the solenoid heat shield in my Chevrolet parts catalog is #361443 - in group 2.104. It's listed as Chevelle w/Sp. H/per. (454)
Section 2 page 5
Interestingly, on a side note... Apparently, in April of 1983 the cost was $6.55 according to the book.
Summit and Jeg's both show one for less than $20.00. It is not stainless steel but, it references this GM number.
Toppless72 is offline
post #15 of 17 (permalink) Old Jul 21st, 19, 11:20 AM
Eugene
Section 2 page 5
The starter shield you are looking at is a superseded part. #361443 was different than the original and was not stainless. Your catalog is from 1983 so there is probably a lot of superseded part numbers.
Bonkerman is offline
