I need help on removing my 66 glove box lock - Chevelle Tech
  • 1 Post By Cal Malibu
post #1 of 7 (permalink) Old Apr 27th, 19, 3:57 PM Thread Starter
I found this but the photos have disappeared. Can someone help. I have my key but can't seem to find that little hole I am suppose to put a paper clip or a small screw driver in to depress ? Can't seem to find anything online about a 66-67 chevelle glove box lock. Thanks
Jim_66SS is online now
post #2 of 7 (permalink) Old Apr 27th, 19, 4:40 PM Thread Starter
Re: I need help on removing my 66 glove box lock
https://www.chevelles.com/forums/35-...-box-lock.html
This is the previous discussion
post #3 of 7 (permalink) Old Apr 27th, 19, 5:43 PM
I tried to add the pics back into the old post but this site wont allow it for some reason.
Here are the pics again..
See the little push in tab next to the dash?Push that in while gently pulling out on the tumbler, It will only come out a little bit, then push in the hole again and gently pull out on the tumbler, it will come out just a little bit more, do this until the tumbler is all the way out..
I didn't have an Allen wrench big enough to turn the assembly nut off, I used a flat piece of steel to put in and turn it..
1953 Chevy Bel Air 4 door.
1968 Chevy C20 CST Longbed.
1967 Malibu 396 Powerglide.
Cal Malibu is offline
post #4 of 7 (permalink) Old Apr 27th, 19, 9:40 PM Thread Starter
Thanks, thats the hole at the 3:00 position when facing the dash that I tried. I kept pushing in; but not luck. There must be something wrong with my tumbler. I will try again tomorrow, thanks
post #5 of 7 (permalink) Old May 2nd, 19, 11:32 PM
David
"I didn't have an Allen wrench big enough to turn the assembly nut off"
Its not an Allen wrench to turn the nut because the nut requires an eight sided input tool! (Allen wrenches are 6 sided)
If you know of a friend with a 3D printer - have him grow one for you
66 Malibu......on it's way back to life as a BB
RAIDER SS is online now
post #6 of 7 (permalink) Old May 3rd, 19, 1:17 AM
Easier to just use a flat piece of steel to span the inside, I Dont have a friend with a 3d Printer, His wife is a D cup though..
Pete 67 likes this.
post #7 of 7 (permalink) Old Jun 3rd, 19, 10:27 AM
lou
Send a message via AIM to roadster601
very interesting mmmmmmm
lou
roadster601 is offline
68 glove box lock removal 68elky396 Interiors 5 Dec 4th, 18 9:26 PM
1966 chevelle glove box lock 3karfan Interiors 1 Aug 23rd, 14 3:03 AM
1970 chevelle ss 396 auto atlanta buildsheet box decode CSS1970396 Restoration Corner 12 Jan 13th, 13 10:03 AM
IGNITION KEY SWITCH & GLOVE BOX LOCK RACER70 1999 -- 4 Mar 27th, 99 8:32 AM
Glove box lock Joe Harrison 1999 -- 5 Nov 11th, 98 5:57 AM
