72 Chevelle 454 oil sending unit/sensor - Chevelle Tech
post #1 of 2 (permalink) Old Feb 27th, 19, 1:15 AM Thread Starter
MK
Hey everyone,
Need some help with my oil gauge set-up. Looking at the assembly manual, I am seeing what appears to a sending unit that mounts on the block between the #1 and # 2 cylinder and then that mount to a tee at the Oil filter, both on the right side. Are both needed? I have converted a amp meter to and oil gauge and wasn't sure about the other. I have all gauges, no lights in my cluster.
Thanks,
MK
Certifiable
Swateam72 is offline
post #2 of 2 (permalink) Old Feb 27th, 19, 10:20 PM
leo
Re: 72 Chevelle 454 oil sending unit/sensor
cylinder #1 is on the left(drivers side) and cylinder #2 is on the right(passengers side), I believe you are talking about the Temp sender in that location and the oil sender is above the Oil filter, also on the left side. The side is determined by sitting in the driver seat.
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
LeoP is online now
This Thread is more than 402 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
What weight oil do u use? lucky3 Performance 68 Jan 14th, 15 5:26 AM
NASCAR Racing Oil Test Results 540 RAT Performance 19 Aug 22nd, 13 8:07 PM
Oil for my BB 396 Carolina69 Engine 12 Jun 14th, 13 5:38 PM
Premature Bearing Failure Loper93 Engine 75 Oct 6th, 12 2:47 PM
