66 Malibu Heater Core and Box Refresh - Page 2 - Chevelle Tech
 4Likes
post #16 of 17 (permalink) Old Mar 1st, 19, 10:34 AM Thread Starter
Re: 66 Malibu Heater Core and Box Refresh
I received a message asking about the heater box and Evaporust. I had meant to mention both topics earlier.
One thing the rebuild/gasket kit mentioned was to drill out the spot welds of the heater box. That will allow you access the flaps on the inside. I didn't replace those pads because they were in good shape and I didn't want to drill out the spot welds. After drilling them out, it's recommended to use pop rivets to seal it back up.
As for the Evaporust, after experimenting with a one gallon jug on smaller pieces,I purchased a 5 gallon bucket of the stuff. I then poured all 6 gallons into a slender plastic garbage can to soak overnight. Only about half of the heater box fit into the garbage can. After it soaked, I would rinse off that half, remove some paint and rust chunks, then dry it and soak the other end. I actually did this twice on each end. You need to dry it immediately after rinsing it with water, otherwise it will flash rust.
1966 Malibu 327 200-4r
brockmub is offline
post #17 of 17 (permalink) Old Mar 1st, 19, 11:00 AM
Drew
Thanks for that.
Droff is offline
68/69 Heater Core change - Need to remove the firewall box? RAMBO Heating & Cooling 7 Jan 25th, 18 1:29 PM
LS Swap - Heater Core Hack pnugene LSx Engine 7 Feb 20th, 17 3:19 PM
Heater Core Box jegreen Heating & Cooling 2 Feb 15th, 17 8:42 AM
Heater core replacement - 69 with A/C Slipstick Heating & Cooling 3 Dec 16th, 14 11:31 AM
1967 Chevelle Heater Core Box sd96 Body Shop 9 Oct 12th, 12 7:20 PM
