1966 SS396 brass oil fitting - Chevelle Tech
 2Likes
post #1 of 16 (permalink) Old Feb 12th, 19, 8:53 PM Thread Starter
Could someone be nice enough to post a picture of all the factory fittings needed to connect to a U14 factory oil gauge from the engine to the actual gauge?
I cannot figure out what I need.
Mike Vercheak
mjv1953 is offline
post #2 of 16 (permalink) Old Feb 12th, 19, 9:15 PM
Re: 1966 SS396 brass oil fitting
What year,block, and transmission?
Jim_66SS is offline
post #3 of 16 (permalink) Old Feb 12th, 19, 10:03 PM Thread Starter
Hi Jim,
One for a 1966 Chevelle SS396 396/325 4 speed
thanks,
mjv1953 is offline
post #4 of 16 (permalink) Old Feb 13th, 19, 3:46 PM
Originally Posted by mjv1953 View Post
Hi Jim,
thanks,
Here's a kit. Posible that you may need an adapter at the block? Or a grommet for going thru the firewall...
https://www.ss396.com/nova/N-1131.html
You need something like this special fitting at the gauge... Not sure this is the correct one though...
https://www.napaonline.com/p/WH_6100X2
Eaton/Weatherhead #6100X2
TC #1366
Sold
Sold
1966_L78 is offline
post #5 of 16 (permalink) Old Feb 13th, 19, 7:54 PM Thread Starter
Jim,
Thank you very much for your reply. I was wondering if there was a special fitting that went in the block first.
Thanks again,
mjv1953 is offline
post #6 of 16 (permalink) Old Feb 14th, 19, 7:15 AM
Walt
Oil line fitting in AIM
Name:	Oil line fitting.jpg
ID:	586344   Click image for larger version
wahubb is offline
post #7 of 16 (permalink) Old Feb 14th, 19, 12:14 PM
That is everything shown Walt. The Special clip #22 is almost impossible to find. In 66 the tube was a copper tube. In 67 that changed. If someone is looking for the correct fitting and tube you have to be careful when dealing with venders. James Hinshaw is the guy to contact.
paul bell likes this.
Jim_66SS is offline
post #8 of 16 (permalink) Old Feb 14th, 19, 12:16 PM
Jim,
Thanks again,
Yes bushing 444026, then the fitting with the elbow goes into that. Then the connector, then the sleeve that connects the tube.
Jim_66SS is offline
post #9 of 16 (permalink) Old Feb 14th, 19, 1:02 PM
Walt
Hinshaw does list the Clip, Fittings, and Firewall Grommet page 30.
https://hinshawschevelle.com/index.p...urrent-catalog
wahubb is offline
post #10 of 16 (permalink) Old Feb 15th, 19, 3:49 PM Thread Starter
Thanks for everybody's feedback and suggestions of what to do to solve my problem. I was hoping to be able to see a picture of the bushing and the fitting with the elbow to see what an original ones looks like as the drawing in the assembly manual is not that clear to me. I have some friends the a lot of different fitting and was hoping I might score an original one if I knew exactly what one looked like.
Thanks again for everyone's help and input as it is really appreciated.
mjv1953 is offline
post #11 of 16 (permalink) Old Feb 15th, 19, 5:25 PM
I will take a photo this afternoon and post tonight. But its in the car
Jim_66SS is offline
post #12 of 16 (permalink) Old Feb 15th, 19, 7:13 PM
Now I know why I didn’t do this before. If you want the correct stuff call James hinshaw or paragon, otherwise cobble something together or get incorrect parts some some other vender.
1st photo shows copper tube from above, 2nd photo shows clip with tube through it at manifold bolt, 3rd photo is you guess as well as mine- connector/elbow/bushing.
ID:	586454   Click image for larger version
ID:	586456   Click image for larger version
Jim_66SS is offline
post #13 of 16 (permalink) Old Feb 15th, 19, 8:01 PM
I think Heartbeat City (Camaro vendor) sells the right parts too.
But make note that I have seen several vendors offer a kit that is listed as being for all big blocks, but it is actually only correct for the 4-bolt main blocks. The fitting that screws into the block AND the elbow fitting are different on 2-bolt blocks versus 4-bolt blocks. So make sure whatever vendor you buy from lists both kits, so you know that they know the difference and will be sending you the right one.
Jeff Helms
-65 Z16 Survivor (Red/black/white int.) (
-65 SS Convertible (Red)
-66 SS L34/M20 Survivor Coupe (Aztec Bronze) - 'Vintage Legend' Certified (
jeffschevelle is offline
post #14 of 16 (permalink) Old Feb 15th, 19, 8:45 PM
Thinking the different kits due to the oil cooler on the 4 block and no oil filter on the 2 bolt.
Is the oil line correct for 66? Looks correct for 67.
Jim_66SS is offline
post #15 of 16 (permalink) Old Feb 15th, 19, 9:00 PM
Andy
The 4 bolts are 3/4 pipe threads.
Andy's Auto Repair is offline
Zinc Myth and Test Data on a Dozen more Oils 540 RAT Performance 59 Jan 29th, 18 7:06 AM
Oil leak..switch from 10w 30 to 20w 50? Bikebro Engine 10 Jul 24th, 14 9:11 PM
Test Data on 3 more Diesel Oils – Surprising results 540 RAT Performance 1 Aug 15th, 13 9:44 PM
Best Oil Tom T Engine 21 Mar 18th, 13 9:33 PM
Royal Purple Oil Motorhead62 Engine 21 Feb 5th, 13 2:30 PM
