Restoring a 67 "138" Convertible - Chevelle Tech
 39Likes
post #1 of 76 (permalink) Old Sep 5th, 18, 11:40 PM Thread Starter
Beth
Hi,
I just scored a great find, a very rust-free 67 original SS convertible that came with 4 speed, bucket seats and Marina Blue paint. It still has the original 12 bolt but the engine/trans are gone.
I was able to buy it minus the engine/trans for 25k which I think is a great deal considering it's ready to paint and there is no rust in the quarters, doors, fenders and floorpan. The car must have been a garage queen.
I want to update the brakes, steering, etc while keeping a totally stock look.
It has front drum brakes and manual steering! Amazing that they are untouched.
I have a 454/T56 ready to drop in. The 454 will be badged a 396.
Will it hurt the value much if I change the stock black interior to blue or white ?
Marina blue paint with a white or light blue interior is more appealing than black to me.
Pics :
ID:	574078   Click image for larger version
ID:	574080   Click image for larger version
Name:	Trunk floor.jpg
ID:	574082   Click image for larger version
Name:	Rear view 12 bolt.jpg
ID:	574086   Click image for larger version
ID:	574088   Click image for larger version
Name:	Rust free floorpan.jpg
ID:	574090   Click image for larger version
Name:	Engine bay 2.jpg
shovelrick likes this.
67 Chevelle convertible, 138 vin, original 4 speed, bucket seats, 12 bolt, Marina Blue with black interior
nashville beth is online now
post #2 of 76 (permalink) Old Sep 6th, 18, 12:00 AM
Greg.
Re: Restoring a 67 "138" Convertible
Beth great find
But I see a few things that would make me question if it is a True SS396 car
1. Dash has the fake Wood Grain strip on it instead of the Black Wrinkle one
2. The Rivets on the Firewall Plate seem not to be Original types and that Plate seems to new looking
just MHO and I could be totally out in Left Field
the heckler likes this.
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.561
1/8 = 7.411 et / 90.18 mph
1/4 = ??.??? et / ??? mph
Kirk's67SS is offline
post #3 of 76 (permalink) Old Sep 6th, 18, 12:03 AM
Congratulations on your find. I’d install whatever color interior and top you like. It’s your car, build it as you like. If it hurts the value, it likely won’t be significantly.
Steve R
1966_L78 and Alan F like this.
Steve R is offline
post #4 of 76 (permalink) Old Sep 6th, 18, 2:52 AM
Steve R
I agree, its your car, do as YOU like... The interior change may make a slight difference in the value, but it shouldn't be anything to worry about. More likely, any value change will be someone's perception, whether they like the Blue or White, or Black...
... IMO, the T56 will potentially hurt the value, because it requires cutting into the floor and fabricating a new transmission tunnel...
IIRC, "White" was not an option for 1967... But you can get it easy enough today... For '66, the factory "White" interior had the seat covers, upper door panels/arm rests in "white", while the carpet, seatbelts, dash, A-pillars, lower door panels and painted door tops were "Black"... If you went this route, its cheap and easy for anyone to reupholster the seats in black, and swap out the door panels and armrest, should somebody decide they wanted to go factory black...
For my '66 convertible, I chose a semi-custom color combo, using white seats and all-white door panels, but with Bright Blue carpet, dash, door tops, etc... IMO, it looked great, and only a real '66 Chevelle "expert" would realize it wasn't a factory available combo... I thought the white seats really looked great with the Marina Blue...
Name:	conv Interior66.jpg
Steve R and Kirk's67SS like this.
TC #1366
Sold
Sold
1966_L78 is offline
post #5 of 76 (permalink) Old Sep 6th, 18, 3:02 AM
Originally Posted by nashville beth View Post
Hi,
A little hard to tell from the pictures, but it looks like it may have a later 12-bolt rearend… Just looks like more room between the brake backing plates and the lower control arm bracket...
And I am thinking its not an original 4-speed car... Not 100% sure if the 67 SS's with 4-speeds had the same features as the '66, but I cannot see the under-floor clips for the speedo cable routing (passenger side), nor the hole in the firewall below the heater for the 4-speed-specific cable routing...
I agree too, that the cowl tag appears "too nice"...
Kirk's67SS likes this.
TC #1366
Sold
Sold
1966_L78 is offline
post #6 of 76 (permalink) Old Sep 6th, 18, 3:11 AM
Tony’s right, the gap between the lower control arm mount does look too wide. It should be about the width of a thumb. Back when Chevelle’s were cycling through the junkyards, that was parts scavenging 101, that way there was no need to check the width with a tape measure.
Steve R
Steve R is offline
post #7 of 76 (permalink) Old Sep 6th, 18, 3:13 AM
Did '67's start stamping the con VIN under the cowl grill or heater flange? I know my '66 doesn't have them yet...
TC #1366
Sold
Sold
1966_L78 is offline
post #8 of 76 (permalink) Old Sep 6th, 18, 11:44 AM Thread Starter
Beth
I agree the cowl tag does look "nice". It does worry me a little but:
The VIN plate inside the drivers door has the "star rivets" and appears unmolested. In other words "it looks old."
The rear frame has the big block braces and looks the same age as the rest of the frame.
I pointed out the woodgrain on the dash and the owner said he had the original and wasn't sure why it had been swapped out.
Is the floorpan opening for the shifter different for a 4 speed as opposed to an automatic ? Or are they the same ?
The 12 bolt is a CN code which applies to 66-67. Haven't verified if it has the 66 or 67 lower spring perch.
post #9 of 76 (permalink) Old Sep 6th, 18, 11:54 AM Thread Starter
Beth
Tony, I have the regular T56 out of a 95 Camaro; not the Magnum. It should take minimal cutting to get it in.
Your interior looks great ! I might go with a blue interior since white wasn't available. My shifter handle will be a Muncie welded on the T56 handle. I plan on using a console ; I might have to move the shifter handle to get it in the right position.
post #10 of 76 (permalink) Old Sep 6th, 18, 12:20 PM
I've never been a fan of the same color body as gut unless its a match. So light blue, light blue, yes? What I am a fan of, and you may not be, is the classic mix of white and blue as in Tony's car. In fact, give me a Danube Blue car with white gut and I may fall in lust. ( something I beleive was never made)
So its yours, do with it as you wish, imho blue /white is a classy, classic compliment. As seen in Tony's pic. ( and ps, the woodgrain BOP dash dont go with any of it imho)
Nice score BTW! Can I convince you to shoot in in Darkwater Blue with a fawn or cream interior and matching top? One sharp one of-a-kind!
post #11 of 76 (permalink) Old Sep 6th, 18, 12:54 PM
Muncie handle or not, you're still going to need to modify the floor pans to fit that T56.
Clint44, Steve R and Kirk's67SS like this.
64 2 door Wagon
67 2 Door Post Sold 11/21/17
LS1 T56
67 SS Tribute Sold
Pete 67 is offline
post #12 of 76 (permalink) Old Sep 6th, 18, 12:56 PM
I agree with you on that color combo Gene. Would look truly stunning. Being Danube was a '66 only color, & white was an available interior color, it is quite possible that a few were ordered that way. Did any survive is the question.
427L88 likes this.
64 2 door Wagon
LS1 T56
67 SS Tribute Sold
Pete 67 is offline
post #13 of 76 (permalink) Old Sep 6th, 18, 1:33 PM
The floor pan is the same for ALL transmission options, except for the shifter opening "hump". The factory floor is kind of hacked out, and the additional "hump" is welded in place when a floor-shifted manual is ordered. The floor shifted auto has a different hole (also depends on Powerglide or TH400, but your frame does NOT have the TH400 cross-member brackets).
BTW, the "4-speed" hump is also the same as the factory "3-speed manual" hump, but the 3-speed (which was standard equipment for the SS 396) used the driver's side speedo cable routing...
"CN" was also used in later years. I know CN was a rearend code for 1969. IIRC, 1970 used "CCN" as well... If you are under the car anyway, just write down the casting number from the center section...
They make bolt-on brackets (assuming your T56 shifter has the standard "Hurst" 2-bolt handle mounting. Someone may also make a new "repro" handle to bolt to the Hurst pattern shifter... I know I bought one for my '66, but the '67 handle differs in its bends).
TC #1366
Sold
Sold
1966_L78 is offline
post #14 of 76 (permalink) Old Sep 6th, 18, 3:39 PM Thread Starter
Beth
Do you have any pictures of these brackets ? The crossmember looks very much like the Camaro TH400 xmember.
I just found "CN" listed as 66-67 only : 1967 Chevelle Rear Axle Codes
The floorpan has the welded mounts for bucket seats and a pic of the forward console mount bracket is below.
Someone mentioned a hole in the firewall for the muncie speedometer cable.
There is a pic of the firewall attached.
What is the stock swaybar on SS396? I think it's 15/16"
I think I will go with the white interior with the Marina Blue paint.
Name:	Console mount.jpg
ID:	574132   Click image for larger version
ID:	574134   Click image for larger version
ID:	574136   Click image for larger version
Name:	Heater firewall.jpg
Name:	Clip below heater.jpg
1966_L78, 427L88, LeoP and 1 others like this.
post #15 of 76 (permalink) Old Sep 6th, 18, 3:50 PM
Good choice!
My true doc'd 138 car has both holes Beth, like your ragtop. I only this year routed the speedo cable thru the proper pass side "SS" hole and not the "Malibu" hole the PO's had it running thru. I had no idea until I checked the Assembly Manual!
BTW, the serial number will also appear near the trunk lid seal on your rear fender up near the front corner. Yet, why worry about it's authenticity unless you're going to flip it.
All the more reason to dress it as you want it.
Paul I looked at all the color combos over at CHEVELLESTUFF, which is an awesome reference site, and couldnt find it. I did see a 69 in midnite blue with ivory interior back in 1978 and it was very classy. A repaint. That combo looks good on Chevelles, Jaguars, etc, everything,imho. See if DUKE69 has his car pic in his user profile here.
Pete 67 likes this.
