1966 firewall holes... Anyone have pictures? - Chevelle Tech
post #1 of 6 (permalink) Old Feb 7th, 18, 2:41 AM Thread Starter
On my '66, it's been disassembled for more than 30 years. I know there are several "extra" holes on the firewall (aftermarket coil for one), but there also a few others I am not sure about...
It is a 4-speed, with gauges and a tach, so it has the holes for the tach feed wire, the oil gauge line and the reverse light harness...
I am also not sure which holes go with the insulation pad and push-pins...
I'd like to weld up the un-needed holes...
Name:	resized firewall.jpg
ID:	521473   Click image for larger version
Name:	resized firewall2.jpg
TC #1366
Sold
Sold
1966_L78 is offline
post #2 of 6 (permalink) Old Feb 9th, 18, 2:11 PM Thread Starter
Re: 1966 firewall holes... Anyone have pictures?
Anyone????
TC #1366
Sold
Sold
1966_L78 is offline
post #3 of 6 (permalink) Old Feb 9th, 18, 10:20 PM
Mines been smoothed over so can't help.
USN-SSBN 645-G
boyd66k20 is offline
post #4 of 6 (permalink) Old Feb 11th, 18, 1:09 PM
Looks like there was nothing on the pass side of my firewall. My tack line is in a different location: but as you can see there were some different holes drilled at one time. Tack groument andoil line groument appear to be origional.
Backup lights in different position also, probably should look at a fremount firewall.
ID:	523041   Click image for larger version
Jim_66SS is offline
post #5 of 6 (permalink) Old Feb 11th, 18, 1:30 PM
Banned
Cory
I think that you have identified each hole properly based on the 3 66's I've worked on.
Also: You may already be aware - you are missing a pinch clamp on the steering shaft (mast per AIM) below the lower bearing. Without it the mast can slide up toward the cabin and result in an unwanted gap between the steering wheel and signal cup.
dream66 is offline
post #6 of 6 (permalink) Old Feb 11th, 18, 11:30 PM Thread Starter
Thanks,
Mainly on the center-driver's side of the firewall, I have those unknown holes... Several look drilled, but a few look almost stamped...
Yes, I am aware of the missing clamp... Now if I can only find it. That's what I get for disassembling this thing more than 30 years ago... Not visible in those pictures, but the lower column bearing race has slid a bit further down the column... kind of rusted in place now...
I have a new lower bearing and plastic bearing housing (IIRC, from Hinshaws?), as well as a new turn signal switch and upper bearing...
TC #1366
Sold
Sold
1966_L78 is offline
This Thread is more than 842 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
