Chevelle Tech - View Single Post - Removing a 72 Chevelle dash pad
post #3 of (permalink) Old Jan 20th, 04, 3:20 PM
71chevelleconvtble
Earl
Post
Brandon, the headlamp switch is held in place by a screw. Use a big screw driver to install it between the dash and switch. You should be able to do this without removing the dash pad. You have to reach under the dash and depress a button on the side of the switch to allow you to remove the headlamp knob. Might be a good idea if you disconnect the battery before reaching under the dash so you don't short anything or get shocked.
Good Luck
71chevelleconvtble is offline
