Chevelle Tech - View Single Post - Removing a 72 Chevelle dash pad
post #1 of (permalink) Old Jan 19th, 04, 1:55 AM Thread Starter
BK72SS
Rebel Rouser
Post
I just want to get some advice on removing the dash pad on my 72 Chevelle, I can see the screws that hold it on but I seem to remember reading on here that there are also some clips near the windsheild that also hold the dash pad on. What do these clips look like, can they fall into the dash (in the wiring) when I remove the dash pad? This is on a 72 Chevelle with the SS dash (round gauges). The reason I need to remove the dash pad is because when I turned my lights off the light switch went into the dash and now flops around in the opening in the guage cluster. Also whats involved with fixing my lightswitch problem, does it clip on or is there a screw. Thanks for any help.
Brandon
Brandon
1972 Chevelle SS: 383 Stroker, TH350 3500 Stall, 12bolt 4.10's posi: Best ET 1/4 [email protected], 1/8 7.34 @91mph, 1.597 60ft
1987 Silverado 3/4 4X4: 350TBI, TH400, 4.10's, 6" lift and 35's
2002 Camaro SS: LS1/A4, stock daily driver
2013 Silverado 4X4 crew cab
BK72SS is offline
