New prob for the masses..."stuttering" engine - Page 2 - Chevelle Tech
2002 General Tech questions from 2002
post #16 of 24 (permalink) Old Dec 13th, 02, 9:28 PM
This is what they look like.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1874543690
Randy Mosier is offline
post #17 of 24 (permalink) Old Dec 13th, 02, 10:33 PM Thread Starter
I need it! And it's even close to me!
I could do my own emissions testing too, huh? C'mon! Everyone chip in and you can come by and get analyzed whenever you'd like!
70 Impala Sport Coupe (350)
67 Chevelle (I wish, still looking and saving)
http://www.geocities.com/ledsled_26m
ledsled is offline
post #18 of 24 (permalink) Old Dec 13th, 02, 11:31 PM
You can't go wrong! For these older cars, those machines are excellent for diagnostic work. Once you learn how to read the sine wave, you can quickly tell if a problem is due to an ignition propblem or other mechanical problem.
post #19 of 24 (permalink) Old Dec 14th, 02, 4:54 PM
Obviously running too rich will cause plugs to foul, and it will begin to miss.
Another possibility is that your fuel filter is clogged. If you are only having troubles under hard acceleration, you could be starving your carb for fuel.
For rich conditions, don't forget to look at your choke, expecially since it is colder outside now.
dwebb210 is offline
post #20 of 24 (permalink) Old Dec 14th, 02, 7:31 PM
I recently had a similar problem, #8 plug had come loose. This has happened a few times now.
Bob B. is offline
post #21 of 24 (permalink) Old Dec 15th, 02, 12:34 AM Thread Starter
I replaced the plugs and threw in a new set of custom-cut Accel wires, and the problem's gone!
I don't see the logic in it...but it works, so good enough for me.
Thanks all!
ledsled is offline
post #22 of 24 (permalink) Old Dec 15th, 02, 7:10 PM
As engine RPM increases, the pressures inside the cylinders increase. The pressure of the fuel/air mixture can build to the point that there is enough resistance to snuff out the spark across the gap of the spark plug if there are any weak components in the ignition system.
post #23 of 24 (permalink) Old Dec 15th, 02, 7:44 PM Thread Starter
Ahh, cool.
I was inspecting the old wires today, and a few had cracks right along where they sat close to the exhaust manifolds.
They weren't that old...perhaps 3 years. They were Accel 8mm's. Guess I'll have a more rigorous replacement schedule!
ledsled is offline
post #24 of 24 (permalink) Old Dec 19th, 09, 11:25 PM
Re: New prob for the masses..."stuttering" engine
Well, did you fix it?
Netruckcap is offline
This Thread is more than 3821 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
You may not post new threads
You may not post replies
