Broken Bellcrank Repairable ???? - Chevelle Tech
 2Likes
  • 2 Post By gnicholson
post #1 of 11 (permalink) Old Aug 26th, 17, 11:16 PM Thread Starter
My original GM '67 Big Block Bellcrank broke, can this be repaired? if so what would be the best way to fix this TIG? MIG? ,
ID:	469434   Click image for larger version
ID:	469442   Click image for larger version
1967 Chevelle Oshawa Built Car
-427 .60 over, Lunati 60211 Roller cam
-Super T10 2.64
-Dana 60 3.54 Posi
1967 chevelle is offline
post #2 of 11 (permalink) Old Aug 26th, 17, 11:47 PM
Gary
Re: Broken Bellcrank Repairable ????
any good weld process for steel will work fine tig being the best
gnicholson is offline
post #3 of 11 (permalink) Old Aug 26th, 17, 11:47 PM
I would have that TIG welded. Clean it up real good. You have to get all the grease, paint, rust, oil, ect. off the part. Clean several inches away from the repair.
I always charge less with a cleaned up part. To bad you don't live just a little closer
If you lend someone $20, and never see that person again, it was probably worth it.
Molly's 70 is offline
post #4 of 11 (permalink) Old Aug 26th, 17, 11:49 PM
Tom Lloyd
This is common with 66-67 bell cranks
I have welded many with a MIG. I have a piece of Copper that fits inside to limit weld on the ID. Careful alignment of the ring groove helps. It takes a bit of skill to not to make a huge glob of weld on the outside as it was a pretty fine weld from the factory.
Good luck, you can always grind and try again, don't be afraid to start.
Tom Lloyd
take my advice, I'm not using it.
floyd66 is offline
post #5 of 11 (permalink) Old Aug 26th, 17, 11:58 PM Thread Starter
I can get access to a Glass bead machine, would this be safe to remove all paint and rust without damaging the broken area?
-Super T10 2.64
-Dana 60 3.54 Posi
post #6 of 11 (permalink) Old Aug 26th, 17, 11:59 PM Thread Starter
what size of copper tube did you use?
-Super T10 2.64
-Dana 60 3.54 Posi
post #7 of 11 (permalink) Old Aug 27th, 17, 1:44 PM
I also add a layer of reinforcing around the tube and up the flat arm at least 1 inch both sides. While you are into it - do the other end too - just a matter of time for it too. Make a loop out of 3/16" round rod, it is easy to form around the tube and up the other side.
*Harley - 06 Street Bob
*Peach State Chevelle Member
*Retired June 1, 2014****
OLDED is offline
post #8 of 11 (permalink) Old Aug 27th, 17, 10:52 PM Thread Starter
If I were to reinforce the side that broke by adding a piece of steel (see pic) would this help or do you see it interfering it with anything??
Name:	chevelle z bar reinforement.jpg
-Super T10 2.64
-Dana 60 3.54 Posi
post #9 of 11 (permalink) Old Aug 27th, 17, 11:45 PM
Devin
I broke mine in high school, somewhere around 1990-1991. Welded the arm back in and reinforced it with 1/4x1 steel strap welded all the way around it and a triangle on the inside. No interference and it never broke again. When I swapped over to big block, I did the same thing to the new one and never had trouble from it either.
Devin
Just an El Camino
Son's build:
My never-ending project:
64SS427 is offline
post #10 of 11 (permalink) Old Aug 28th, 17, 12:25 AM
Just get as much grease & oil, paint ect. off that part first. then blast it. A quick wipe off with some Acetone, MEK or MPK will clean off any residue.
Clean & Clean makes for a better weldment.
post #11 of 11 (permalink) Old Aug 28th, 17, 2:39 AM
Gary
send it to me and pay for the postage back and ill fix it for you
floyd66 and davewho1 like this.
This Thread is more than 908 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
