1972 Chevelle SS 454 convert limited slip - Chevelle Tech
 2Likes
  • 1 Post By big gear head
post #1 of 9 (permalink) Old Jun 20th, 17, 10:03 PM Thread Starter
to a posi eaton..can some one tell me what all I need? I have a 331 12 bolt in my car now..can I just put the ring gear onto the posi and bolt everything back up?
TC #0672
1972 SS 454 M22
"W " Code Midnight Bronze
Bandit1978 is offline
post #2 of 9 (permalink) Old Jun 20th, 17, 11:36 PM
Re: 1972 Chevelle SS 454 convert limited slip
You'll need a 3 series posi, a installation kit a d someone that knows how to set the gears up properly. Jim
Jim Mac is offline
post #3 of 9 (permalink) Old Jun 21st, 17, 12:11 AM
Freddie
Posi is limited slip. If you have a standard differential now and you want to upgrade it to a limited slip differential then you will need a 3 series Eaton Posi, Eaton Truetrac, Yukon Dura Grip or whatever limited slip differential you choose. You will also need bearings and shims to set the backlash and bearing preload.
Rex Auftinn likes this.
big gear head is offline
post #4 of 9 (permalink) Old Jun 21st, 17, 12:51 AM
Lightbulb Re: 1972 Chevelle SS 454 convert limited slip
This is also when you need to decide if you want or need stronger axles, now or eventually.
If you decide not now, but later change your mind (stronger engine, etc.), you'll need another new posi-unit to match the spline-count on the upgraded axles.
Rex Auftinn is offline
post #5 of 9 (permalink) Old Jun 21st, 17, 10:20 AM
Its that issue, Big Elephant Engine , Now from the crankshaft to the rear tires and everything in between. The Cash register starts to go " Cha-Ching " a day or two pause, Then Cha-Ching again and again.
Old cars are like a Willie Nelson song, " You got the Money Honey, I got the time ".
Robinls5 is offline
post #6 of 9 (permalink) Old Jun 21st, 17, 10:23 AM
Andy
Rex, there are a 1/2 dozen choices on performance axles that are 30 spline.
Andy's Auto Repair is offline
post #7 of 9 (permalink) Old Jun 21st, 17, 10:31 AM
Freddie
I don't recommend using 33 spline axles with c clips. If you upgrade to 33 spline axles you need to install new housing ends with press on 9 inch Ford axle bearings, or at least use c clip eliminators. 33 spline axles are almost the same size as the c clips, so there is a chance that you could loose an axle. Moser doesn't make 33 spline axles for the 12 bolt with c clip buttons. For most street cars the 30 spline axles are plenty strong.
You do need to check the axles for wear where the bearigns run on them. If they are worn or pitted then they need to be replaced.
Kirk's67SS likes this.
post #8 of 9 (permalink) Old Jun 22nd, 17, 2:18 PM
Smile Re: 1972 Chevelle SS 454 convert limited slip
Yep, I upgraded to the 33-spline axles
with the Ford Torino "big-bearing" ends
on the new Moser.
Ready for engine upgrade, should that come along.
Very nice knowing it's ready, whenever I (or the next owner) might need it.
The Moser build-choices were my "ounce-of-prevention".
post #9 of 9 (permalink) Old Jun 22nd, 17, 2:28 PM
Eddie
This is what I did on my 12 bolt.
Motive Gear Ten Factory Axle Shafts MG22109
Motive Gear R12CRMKT Differential Master Bearing Kit
Eaton Posi 19554-010 3 series posi
Few other goodies but this is the basic setup.
Eddie K is offline
This Thread is more than 1006 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
