Muncie M-20 for '68 el Camino - Chevelle Tech
post #1 of 8 (permalink) Old Oct 26th, 16, 5:28 PM Thread Starter
Bruce
My '68 el Camino SS 396 has the correct factory motor (325) with VIN stamped on the pad and the correct 12 bolt rear, the Muncie trans in it is dated P7D067, which is too early for the COWL tag 12C build date, so not the original trans. Has the speedo output on the passenger side. Also VIN code stamp does not match.
I came across a Muncie trans (M20 - 2 grooves on input shaft) datedP7P30 which would work, only issue is the speedo output is on the driver side, the casting numbers are:
Main housing - 3885010
Tailshaft- 3846429
Side Cover - 3884685
Does not look like it has a VIN code stamped in it?
Would the '68 SS 396. 325 hp have the speedo output on the passenger or driver side? This one might be for an Olds or Pontiac?
Checked my Colvin, ChevelleStuff, no real help?
'68 el Camino SS 396/325hp, 4 Speed, 3.31, Buckets, AC
'72 el Camino SS 454 4 Speed, 3.73 Eaton LSD, Buckets, AC
'75 el Camino SS, 400 SB, 200R4, 3.42 LSD, AC, Swivel Buckets, PW, PDL
'87 el Camino SS 305 TPI, 200R4, 3.73 LSD
'87 Buick Grand National (Hardtop, Bucket Seats)
PaceCarNut is offline
post #2 of 8 (permalink) Old Oct 26th, 16, 8:01 PM
Re: Muncie M-20 for '68 el Camino
Tailshaft- 3846429
I believe 63-65 were driver speedo and 66-74 were all pass. speedo exit.
What's wrong with the Muncie in the car besides date codes?
Recheck your date code on your installed trans. D= April, 67th?
Video:
fr8dog is offline
post #3 of 8 (permalink) Old Oct 26th, 16, 9:23 PM Thread Starter
Bruce
Nothing wrong with it.
Date code is P7D03, typo on my part! :-(
Heard that possibly they carried over the speedo on the driver side beyond '65 into '68 with Old's & Pontiac's, any truth to that? ChevelleStuff showed the tailshaft number but no application?
post #4 of 8 (permalink) Old Oct 26th, 16, 10:56 PM
I believe you are correct. Here's a link that states some Pontiacs got the driver side speedo up to about 1970:
muncie speedometer gear - ChevyTalk - FREE Restoration and Repair Help for your Chevrolet
Video:
fr8dog is offline
post #5 of 8 (permalink) Old Oct 29th, 16, 11:51 AM
The Muncie trans coded P7P30 was built Sept. 30th 1966 for 1967 model year... P7D03 was built April 3rd 1967...
Neither trans is correct for 1968 model year, but will fit in a 1968 Car just fine...
The driver side speedo tail housing was used in Pontiac A-body's thru the end of the 1970 model year...
Hope this helps... Crash
crashent is offline
post #6 of 8 (permalink) Old Oct 31st, 16, 12:53 AM
Hi Bruce,
PM sent.
Hopefully this will help:
Muncie 4 Speed Transmissions and Parts
3846429 ~ 1963-1965 Regular thick web, driver speedo, 27 spline
Used up to 1970 in some Pontiac Models
Tory
ACES Member #1890
Team Chevelle Gold #288
1955 Chevrolet Bel Air Unrestored 15,000 Mile Survivor
1955 Chevrolet Nomad
1964 Malibu SS Unrestored 36,000 Mile Survivor ~ SOLD
1964 Malibu SS
1966 Chevelle SS 396 Unrestored 76,000 Mile Survivor
1968 Camaro
1968 Malibu L-79, 1 of 4082 ~ SOLD
1984 Hurst Olds w/ Factory Sunroof, 1 of 99 ~ SOLD
1985 442 White / Grey w/ Factory Sunroof ~ SOLD
Lionel-n-Chevelles is offline
post #7 of 8 (permalink) Old Oct 31st, 16, 7:04 AM Thread Starter
Bruce
How do you get Sept 30, 1966 from P7P30? According to my Colvin book:
P: = Prefix - 4 Speed Muncie
7: Model Year = 1967
E: Month = September
30: Day of Month (September 30)
So are you saying that this is actually built on September 30, 1966 for a 1967 model? From the way I read it, that is built September 30, 1967, what I don't have on either of these trans is the main case casting dates that would clarify this.
End of the quandry on the trans I was looking at anyway, decided to pass on it since the tail housing having the speedo output on the drivers side, that's just not correct for my '68 el Camino.
post #8 of 8 (permalink) Old Oct 31st, 16, 7:29 AM
Cam
Cameron Milne
I was very surprised to discover that in 1971-onward, on Pontiacs, the Warner Super T-10 replaced the Muncie M20 in cars like the Lemans. I would have expected the Warner to replace the Muncie around the 1975 model year (74 on Z28s) but my neighbor's untouched, 1-previous owner low mileage 72 Lemans GT 400 4-barrel with a factory 4-speed had a Super T-10. I also found a 1971 picture on the Pontiac assembly line that showed a 400 with a Borg-Warner trans. The HD close ratio 4-speed was still the Muncie M22 though, through 1972.
I had also heard that Oldsmobile ran the speedo off the front wheel, not the tailshaft around that time. One does tend to hear a lot of rumors though; Olds had front wheel drive on the Toronado so I wonder if that is where the rumor took shape.
"The more you know,
TC Gold #120
Cam is offline
This Thread is more than 1302 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
