I boogered out axle seal on Moser - Chevelle Tech
 2Likes
  • 1 Post By Bullcrappy
  • 1 Post By 70CHEVELLE396
post #1 of 8 (permalink) Old Aug 2nd, 16, 11:27 PM Thread Starter
Bull
I puckered the out axle seal installing it in the new Moser rear.
Now I have get it out (slide hammer?) and install some new ones.
Largest socket I had was 2" and it puckered it in the center.
are these standard seals or do I have to get from Moser?
hope I can just get at Napa or something. see pick below.
OD 2.5"
thanks for info
1969 Chevelle Malibu
73k miles
350/330 crate motor
5 spd - Legend 700
4.11 rear
Holley 4160 600cfm
Original console and bucket car
disc brakes
aluminum rad/elec fans
QA1 adjustable shock/new springs/new tubular control arms front and back / tall ball joints
Bullcrappy is offline
post #2 of 8 (permalink) Old Aug 2nd, 16, 11:37 PM
Re: I boogered out axle seal on Moser
Seals generally have a part number and manufacturer stamped on them. Find it then call your local parts store, they should be able to cross reference it.
Steve R
Steve R is offline
post #3 of 8 (permalink) Old Aug 2nd, 16, 11:56 PM Thread Starter
Bull
Your right Steve. I found them on Summit and they have an application list.
I am pretty sure these are it.
https://www.summitracing.com/parts/m...1/applications
Steve R likes this.
73k miles
350/330 crate motor
5 spd - Legend 700
4.11 rear
Holley 4160 600cfm
disc brakes
post #4 of 8 (permalink) Old Aug 3rd, 16, 2:52 AM
Rich
Bearing Race and Seal Driver Set 10 PC | eBay
Rich
1967 El Camino (White)
1965 El Camino (Sold that junk)
HandOverFist is offline
post #5 of 8 (permalink) Old Aug 3rd, 16, 8:53 AM
Freddie
Go to your auto parts store and tell them you want axle seals for a '79 F150 with the 9 inch rear end. Get the bearing and seal drivers while you are there.
big gear head is offline
post #6 of 8 (permalink) Old Aug 3rd, 16, 10:01 AM Thread Starter
Bull
Ya I am going to invest in that for sure.
73k miles
350/330 crate motor
5 spd - Legend 700
4.11 rear
Holley 4160 600cfm
disc brakes
post #7 of 8 (permalink) Old Aug 3rd, 16, 9:35 PM
National seal number 473229
I used my seal puller to remove after I messed up the first try. I bought a seal driver set from Harbor Frieght.
70CHEVELLE396 is offline
post #8 of 8 (permalink) Old Sep 15th, 16, 11:12 PM
I just want to update this post for future reference. I don't know if the op used this part number seal or not. I got this number after contacting Moser back in 2014. After using this, my axle seal started leaking in 2016. I contacted Moser again, and this time received different info. I was told this time to use a CR15142 seal. Also to watch for a seal that is too thick, as it could contact the bearing press ring, and cause a failure. I was able to buy this from Napa, and according to Moser, that's where they get them too.
HKalin likes this.
This Thread is more than 1226 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
